Ok, the Mustang is pretty new to me and a few little issues to work out. One of the first is that the power seat switch was doing odd things, so when I pressed "up" the seat went up. Press down (nothing) Press "forward" the seat would go down, press "back" and I could hear a motor running just a bit but no activity front or rear.
I am seeing "used" switches for $25-75+++ and new ones even more expensive. My switch was just sitting under the seat, already not connected to the front, just laying loose, so looking at the bottom of it, there are six wires coming in.
My first 'bright idea' was to try and "jump" from one pole to what I thought was the ground in the middle. ZZZZZttt, pretty spark and blown fuse.... So that was a bad idea. Knowing that electrical switches are DIRT cheap, I will just buy one. Not quite as easy as I thought, still not sure if I am just not using the right "keywords" in my search, but my uncle said to go look for mirror switches and wahlah, Dorman 901-332 on Amazon is $13.79 (Prime) Done...
It has arrived, today the wife finally decides she wants to DRIVE the MUSTANG, yeah!! It was a joint deal, giving her a fun ride too, I have a Wrangler I drive a lot in summer. Seat not moving forward back was not an issue for me it was in a good place, her, she was on her "tippy toes" to push the gas, so I GOT to fix this.
I look at the switch again tonight. Decide to tear it apart and figure it all out. Two blown fuses later I have a pretty good idea how it works. Then I break off one of the poles going into the $$$$ mustang switch, well crap. I suspect if I had cleaned it all up it might have worked, but maybe someday later.
So, plan B... cut all six wires off the switch and strip them!!! (Pics coming soon... looks like we have to use external sources for that, sigh..)
Solid Black wire - Ground
Black Wire with white stripe - POWER!! (These might be in reverse but when tested, those two give me 12.x volts!!)
Forward/Back
Red Wire with WHITE stripe
Yellow Wire with BLUE stripe
Up/Down
Red Wire with BLUE stripe
Yellow Wire with WHITE stripe
(Forgive me, I could have these backwards, but those ARE the correct pairings. You can confirm in my pictures of my jumper wires and then the switch itself, they are opposite!!)
Ok, so this is how you can test and confirm your seat motors will move up/down, forward/back!
Using a BLACK jumper cable, I connected the Yellow/white to the Black/White
Using a RED (SECOND) jumper cable, I connected the Red/Blue to the Black/Black.
As soon as you do this, the seat will begin to UP or DOWN. (Or if I have this backward, FORWARD or BACKWARDS)
By moving the jumper cable ends that are hooked up to the BLACK wires to the opposite wire, it will then move the OTHER direction!!! (Pictures will help)
So using this method, I was able to first, determine that YES, my seat moves quite nicely in all four directions!!! (Forward/Back is pretty weak, will clean up the motor in a future post!) So we played around with all this and set the seat currently for the wife. She is quite happy, drove it around the block to confirm, but my first official success working on the Mustang!!!
For the other direction
Forward/Back
Up/Down
