95 accessories on 92 block
Trickflow.GT
hey i got a good deal on a 92 stroker, just wondering if my water pump, and timing cover, and all my brackets are going to fit on this block
ryclef331
YES! They will! MAKE SURE you use YOU timing cover and you're GOLDEN. All your accessories will bolt right up! The TIMING COVER IS KEY!!!
ryclef331
Spyder said:
isnt the water pumps on the 94-95 longer than the fox bodies too?
yes they are but like i said if he uses his 94-95 timing cover and everything else, the 92 block will fit right in. The blocks are the same, its everything that bolts on to them that is different!
T
Trickflow.GT
wicked thanks guys..ill be posting pics when it all starts happening :banana: :banana:
Anrev
The water pumps not longer. Its shorter. By 1.75 inches. And if you plan on using your low oil level sensor then you need to swap pans too. Those 2 items and the timing cover are the 3 things that are different on the 94-95 and the Explorer 5.0L's.
T
Trickflow.GT
what about things like clutch, flyweel, etc...? it will all work? oh and what kind of harmonic balance do i need for a 331? 50ounce?
Anrev
81 through 95 all have a 50 ounce imbalance. So the the clutch, flywheel, HB from the 92 will work just fine. I would upgrade to a better HB if you can afford it. And a better clutch like a King Cobra.
T
Trickflow.GT
thats exactly what im doing...king cobra clutch, 28oz centerforce flywheel, and 28oz HB..my builder has balanced the motor to 28oz previously so thats what im going with ;)
Rlee1773
