Greetings all,
I ordered this kit here http://www.americanmuscle.com/russell-brake-kit-9495cobra.html and i did my research, and it led me to believe the front lines are different on on the cobras then on the gts to fit the cobra calipers (which i have), and the fitting would be the same bwtween gt and cobra, and the rear center, left and right are the same on the gts and cobra, and the fitting would be the same too.
So i received my 5 lines today, and i have 2 different size fittings on these lines, is that normal for a cobra? Because i have one front line with a smaller fitting that fits my currert fitting, and the center has what i believe is the the correct fitting. However both the rear and the other front lines have a diffrent fitting that is larger.
I complained to the company and they said they would send me a new set, but am i mistaking here, and for some reason a 95 cobra has 2 different size fittings? Or am i right and they should all fit right up to my 95 gt?
Thanks in advanced
Thanks in advanced
