07GtS197
Here’s a diagram of the 94-95 turn signal wiring.
The diagram is a little misleading because it shows two bulbs for the front turn signal. I think whoever made it did it for clarity. I don’t have my Haynes manual near me at the moment either so I can’t check it against that. I believe there are two circuits for the turn signals, one for parking lamps and the other for the turn signal. I can see how the parking lamp will still work even after the turn signal fuse blows. Since they both share a ground it’s not the ground side. It’s on the flasher circuit somewhere. My guess is it splits off from the multifunction switch, Scott would probably know. That being the case, pull the shroud and check for continuity from the switch to the appropriate pin on the turn signal.
