tpoteet
- Joined
- Nov 7, 2021
- Messages
- 11
- Reaction score
- 2
Hi, I have a 1995 GT 5.0/AT 103k miles, entirely stock except the new 70mm throttlebody. I’m having an idle issue still after reading plenty of guides on the forum and doing some diagnostics. Basically, RPM drops to around 400 occasionally with smaller jumps between 600-800 with no regular pattern to it. I have noticed it is significantly worst when cold and smooths out slightly at operating temperature. I have checked voltages at TPS, 02 sensor, and IAC. I have replaced the following and associated gaskets: IAT, Throttlebody, IAC Gasket, Spark plugs(.054 Gap), Cap and Rotor set, EGR valve, PCV valve, vacuum hoses, and upper intake gasket. Picture down below for reference. Also have a video of data @ operating temp from a snap on scanner:
