95 mustang gt stops pulling at 120mph
SBThomas
my car will not run past 120. it is not stock,has gt40 heads,intake,manifold,x-cam. 3.55 gears.so why will it not run past 120.. seems to be pulling just not going...
evilcw311
Most Evil Member!
Louisville, KY
Mine would pull up to about 140 just fine with not much more than a cam, ported heads, and a chip.
evilcw311
Most Evil Member!
Louisville, KY
Are you on a stock tune? If not did they turn off the factory speed limiter?
01yellercobra
Does it feel like it's hitting a rev limiter? Or it just kinda sit there?
evilcw311
Most Evil Member!
Louisville, KY
Stock computer speed limits around 125. If it pulls strong to there then just stops that’s your problem.
evilcw311
Most Evil Member!
Louisville, KY
125? I am pretty sure I had mine up to 135 but that was 20 yrs ago....
You also told her you was gonna give her 9”s and it was only 6!!!!!
So maybe your numbers are off just a bit!!! [emoji1787]
AStangThang
Ashland, Kentucky
Stick or auto? Nevermind just seen where you said you was still in fourth. How much power you making?
OLD H2S
Silver Spring Maryland
Tuners would have settings to up the speed if it was in the computer just like the later cars.
It is air drag and old age entropy, the '95/ '96 SN95 were pushing 160 RWHP or less and the highest I have seen listed for a stock tweaked out '96 is 170 RWHP.
These stock engines were putting out .56 HP/CID which is why you see so many of them left. On the track with the stock engine and a good tune I could get to 105 on the straights with a tail wind, engine had 200k on it and the bearings and cylinder walls and leak down at 10%... looked great.
SBThomas
My car has 112k miles. Pulls really hard up to 120, just seems to be all it has. Everything I read says 95 doesn’t have a programmable computer. Still a blast to drive. Lol
evilcw311
Most Evil Member!
Louisville, KY
You have to get either a chip or go standalone
lutter94
South Dakota
I didnt think 94 95 mustang's had a factory speed limiter.
Sent from my SM-G960U using Tapatalk
wbarter
