Just an FYI the throat to the 94/95 cobra intakes is only 70mm wide so unless you port it your not going to get any more power out of any TB bigger then 70mm.
to give an example this is the gasket I got with my 75mm and what I used to port the throat to allow for it to get the full benefit of the enlarged tb. But then if you do this it would also be a good idea to port the lower/upper openings to again allow for more air.
and then after it was all done it looked like this
You can see by the gasket the room you have to work with and the lower intake is the same way.
all you really need to do this is an engine porting kit. I use my pneumatic die grinder but if you didn't have one you could always use your drill. This might limit where you can reach and it will take a little longer since its slower but it would work and isn't all that hard to do.
http://www.cjponyparts.com/eastwood...ign=shopping&gclid=CJauz5SskcgCFcOQHwodmNcH-w
This is the kit I got and I still have plenty of barrels for the next time. But after saying all that I have to warn you that you can go too big and end up loosing torque. I am using a 75m but it is being fed by a vortech blower and meth and 42 lb injectors. Its something that would be upgraded sooner or later if you know that there are upgrades in the future that would need this extra air but until you have the mods to support all the air put in you might hurt your performance. It doesn't sound like your in a huge hurry myself so if that is the case I would take the time to get it as good as it can be prior to installing it by porting and polishing it.
and just tell me ya don't want to polish it?! Only took me 2 years
