yellowgt98
- Joined
- Jan 9, 2015
- Messages
- 14
- Reaction score
- 0
I've had this some issue with my 1997. Replaced the Idle control valve, used CRC cleaner and sprayed the MAF sensor insides making sure I cleaned the little electrical sensors inside and opened the throttle plates and cleaned the throttle body air plates (cobras have 2) I believe GTs have one big plate. The inside of the throttle body was really dirty. After cleaning everything, Everything cleared up and it runs great, idles fine and doesn't die. You supposedly have to make sure you use spray cleaner made to be used on MAF sensors and throttle bodies. CRC sells one spray that is made just for these systems. The car will have to be turned over several times before it will start right after you clean it, but that will clear up once you clear the system out and drive it. If you decide to got this route, it's at your own risk, it worked for me.
