95 V6 wheels Different from GT's?
Sidewinder
Just wondering if there is any difference and if the V6 wheels will fit on a GT. I have a cracked rim that is leaking and I don't have enough monwy now to replace all the rims with what I want. As all 4 of the ones that came with my car are in bad shape I need something to replace them with. I kave a friend that has a set of rims off of a 95 that are 17" in diameter but he is not sure if they were off a V6 or GT. He is going to give all 4 of them to me if they will fit. So will they?
Here's what it looks like. http://www.got4x4.org/eb_mustang/rim.jpg
97blackgt
:dunno:i thnk they will work...just take one of your rims off and swap it ...
Doc_G
Birmingham, AL
yeah dude as far as I know w/the possible exception of the new sn197's needing shims all 5lug mustang wheels are interchangable
Ive got 2k1 cobras on mine and they fit like a charm. Should be same bolt pattern and everything.
94Vert
sn95 v6's had 15" or 16" wheels, so those came off of a gt. they should fit your car just fine. i always liked the way those 3 spoke rims looked when they came out.
fixthedoor
the lug pattern is the same but diameters were different. some sixes came with hub caps or 5 spoke pony wheels (also found on the GTS) and the GT's had the three spoke.
ryclef331
They will fit. Unless you have a cobra. I ran them for 6 months.
94Vert
There were many GT's that came with the pony wheels. Mine did and about 100000 others.
trav_19
yes the tribars will fit any stang there 17" and only came on gt's but gt's also came with the pony wheels 16" ....it took me 3 months to locate some tribars but i got some ;D when i bought the car it came with some 17" konig wheels and i wanted to barf everytime i looked at them haha i figured the stock look would do till i get it painted and get my chromies 8)
Anrev
I have a set of those wheels with good tires Id sell cheep if anyone is interested.
Anrev
Tri-bars same as these
ReplicaR
Same bolt pattern across pretty much every single model. Unless you have 13inch brake rotor kit, you should have no problem fitting V6 wheels. I don't know why would you want to however. You can find some used GT wheels that no one wants for like dirt cheap.
Anrev
$300+shipping. I can take some pics if youd like.
kaue2302
Buth...does this kit comes with tires? Do you shipping from Brazil?
Vallybell
