95Gt stalls only when warm
95GTS302
Hey guys, got a recently new to me 95 gt 5.0/ 5 speed. It’s pretty much stock, but having an issue where it will drive awesome no issues until it gets up to operating temp and pretty much right when the T-stat opens up it seems to want to start stalling out at a stop light unless I two foot it and keep the pedal feathered until the light changes. Looking for any input on anyone who’s had similar issue. No check engine light popping on either? Thinking etc?, o2’s?, vacuum leak only showing it’s ugly head when warm?, iac?, tps? Also notice a slight vibration in the wheel when it acts up. E7B04F6F-DD0A-4D2C-8C96-A727D70784FC.jpeg
I had a similar problem with mine and it turned out to be the wire harness to the tps sensor. One of the clips holding it in place broke and when the motor got hot it would loose contact and show up as my foot on the pedal. Get the motor hot and just grab and pull/tug on any harness you can find and see if the motor changes at all to isolate which one it might be. If you know of a harness with broken clips, start there.
maillemaker
My 1990 E350 with 460 would idle rough when cold. Turns out it was a bad Engine Temperature Sensor. Note this was a different sensor than the gauge temperature sensor. I don't know if the 5.0 is similar or not.
95GTS302
95GTS302
I'd start with a base idle reset (google the proper procedure), and then a smoke check for vacuum leaks.
Yes, I’m taking it up to my buddy early next week to use his smoke machine and see what we find and if it’s not a leak then start troubleshooting from that point.
maillemaker
I built a smoke machine following a youtube video. Made it out of a gallon paint can. Super simple after you buy some nichrome wire. You'll need an air compressor, of course.
Maximum95
Albuquerque, New Mexico
Hey guys, got a recently new to me 95 gt 5.0/ 5 speed. It’s pretty much stock, but having an issue where it will drive awesome no issues until it gets up to operating temp and pretty much right when the T-stat opens up it seems to want to start stalling out at a stop light unless I two foot it and keep the pedal feathered until the light changes. Looking for any input on anyone who’s had similar issue. No check engine light popping on either? Thinking etc?, o2’s?, vacuum leak only showing it’s ugly head when warm?, iac?, tps? Also notice a slight vibration in the wheel when it acts up. View attachment 24391
Beautiful car man! Sorry to hear you are having this issue. As a first step, I would agree with the base idle reset. It's a very common cure for many idling problems!
Typically this happens because the throttle stop is not adjusted properly, and the car is relying on the IAC to idle. The IAC is meant to supplement the idle when loads are engaged, such as air conditioning, power steering, and heavy electrical loads. When you start the base idle reset procedure, you may find that the car will not idle on the throttle stop alone.
Good luck! There are plenty of base idle reset procedure write ups out there.
Rod
Until the engine is warmed up the computer has it in open loop and uses a fixed map for fuel & timing. Once warm it goes into closed loop and the sensors come into play, Mass Air, MAP, O2, Etc. Start by cleaning the Mass Air wires, I have had dirty wires cause bad/no idle more times than I can count, change out the O2 sensors, just do it, no idea how long they were in there and they have a service life. Next take off the IAC anc clean it with carb cleaner, they get clogged bad with carbon, this will most likely fix hunting idle problems.
95GTS302
95GTS302
Thank you for the info, I know the P.O said he cleaned the mass air and changed the iac but I’ll take that with a grain of salt and check both areas. Doing the smoke test tomorrow and then I’m hoping to have some time this weekend to start troubleshooting this issue. Overtime has been extremely plentiful lately and times limited but can’t complain lol.
95GTS302
95GTS302
Thank you all for you advice/guidance guys much appreciated. I will definitely report back my findings and fixes.
95GTS302
95GTS302
So quick little troubleshooting today, vacuum leaks all good didn’t find any, however mass airflow is definitely questionable, if I unplug the mass air it will stay running. So took the sensor out cleaned it and now it will at least try to catch itself before it actually stalls. but still I want to replace the mass air flow Im pretty sure that’s the culprit. Its a cheap Chinese piece of poop right now lol Trying to find a motorcraft 19 pounder mass air flow seems to be hard lol called 2 dealerships and it’s totally obsolete, and the auto value i usually use for the motorcraft parts have been on back order for months. Any suggestions on locating one? Really didn’t want to have to buy a new pro m/ BBk unit or anything like that.
Rod
I would try to Junkyard an OEM, but short of that Napa Auto,Autozone, Advance, O Reilly, any chain brand will work on a stock/ish engine. And they all have a warranty if it doesn't.
95GTS302
95GTS302
Gonna give the o Reilly’s a try I just know when I mess with the for iac’s on my fox & the lightning only motorcraft seem to work well.
Maximum95
View attachment 24621View attachment 24622
I had a cheap MAF on my Mark VIII when I bought it. It was a remanufactured one. I didn't even know such a thing existed lmao! The car would idle fine, but would shut off when you tapped the throttle.
Motorcraft wasn't available for that either. RockAuto carries a Delphi MAF, which is an OEM brand for GM. I would reccomend that one, as it's available for the '95 GT as well. Fixed the problem on my Mark.
Your other option is to go aftermarket. I have a Pro-M MAF on my car. It's been great.
badass98svt
Well so far it looks like the new MAF is the ticket. Haven’t had any stalling issues anymore when warmed up.
What brand is the new MAF?
I had a similar problem on my old '81, and it ended up being the ignition module (In your case, that would be the TFI).
Sounds like you got it sorted though! Well done.
95GTS302
95GTS302
Blue streak electronics. From o reillys
from6to8
nice ride and mine does something similiar. I just made this post in another thread in ref to AC on and what I realized:
I have put a stock radiator ( new but was sitting in my barn for years) on when I put the engine out of my wrecked 95 into my 94 cobra. I did flush the radiator out very well with water even though it was in the barn and decently clean outside of maybe a little dust, shouldn't have been really dusty though I believe. I had a fluidyne on the 95 but it developed a leak at some point and I didn't want to install it with that leak situation though I don't think it was a drastic leak but still.
I did a little diagnosing because my car was doing something crazy besides temping up that I just realized today after specifically checking that it's only temping up with the AC on. It's still around 210 no more than 212-13 here in South Carolina today when it was about 88-90 but humid as hell. Even on days last week and week before where it was about 95-98 and phone weather app said felt like 10 degrees higher, it would still with AC on run 210 no more than 212-13. I have a 192 or 195 stat and with the tune I'm pretty sure it's set to turn the fan on at 180 degrees.
With the AC off it ran around 200 and even as low as about 196-197. What the car was doing specifically after the AC had been running and (Summer of course) if I stop and turn the car off per se at a gas station, the car would start back up fine and idle fine but when I went to take off I had to play with the gas pedal or give it a good bit of a rev because when I just pulled off and had to stop to look at traffic if I hadn't revved it enough it would die. It would start back up though fine but would keep doing that same thing unless I revved it or played with the gas pedal. I could take off and go to a stop light within around 3 seconds and if it hadn't had that much rev ( fuel it seems), it would die. If I did revv it pretty good then it would not die at all. Also once I pulled off from that stop light or if I didn't stop at all and just took off and drove it would not have that issue at all unless I stopped and cut the car off.
So yeah I'm going to likely just try a larger radiator and see if that fixes my AC higher temp situation though it's not overheating but I do know also under the hood is hot as heck lol. I just put the radiator cover back on today after having that off since I dropped the engine in in 2021. Might be a little cooler under the hood now though I doubt that has anything to do with under hood temps with the car at a standstill.
TreeScholar
