96 Cobra. Low compression on 3 cylinders. Please Help.
What’s up everyone. Ok so this may be a long winded post. I’ll try and keep it short. Thanks guys for reading if you do.
So I bought my 96’ Cobra a few months ago. Car was a 1 owner and has 15k original miles. From what I know the engine is stock with a Vortech Supercharger. No other internal mods done. When I first went to go test drive the car it had a slight tap under the drivers side valve cover (nearest the firewall) that has gone away from time to time when the car heats up to operating temp.
So a few weeks ago I took the car to get the tune checked and upgrade a few things to bring it up to date. The gentleman who I brought it to said the car has low compression in cylinders 6,7,& 8. (75,89,75) Now the dude is extremely knowledgeable and has a great reputation. However I’d like some input on what it may be. He’s saying could be a cracked piston. Maybe stuck rings.
Now the car sat from 2016-2020 when I purchased it. It was on a tender and started from time to time but not much from what the previous owner said. And it wasn’t started at all for the last year.
Car only smoke from time to time out of the tailpipes under full throttle. Nothing while idling and has plenty of power. It’ll hesitate every now and then but for the most part it runs solid. Had some blowby where some smoke comes out of the oil cap when removed.
Any suggestions? Thank you guys ahead of time for helping me out.
white95
Apex Junky
Prairieville, LA
That’s tough. Unfortunately, you’re not going to have any definitive answers until you tear it down for inspection.
If it otherwise seems to run fine, perhaps you should consider building a short block in the mean time. Have the heads freshened up while it’s down and enjoy many more years of worry free service.
…or Coyote swap it :cool:
I know that’s unlikely but I’m an extremist :)
apsmith49921
Cylinders 7 and 8 are notorious for ticking because if failed valve guides due to coolant dead heading. It's extremely possible with the extra power and heat the made the problem worse. As someone else said until it's torn down you won't know. It's possible you can get away with rebuilding the heads. I would have them do a leak down test also that will help determine a little bit more before you tear it apart.
Sent from my SM-G988U using Tapatalk
Do the leak down test, but if the rings are stuck or piston cracked, the leak down results may come up skewed.
If you are getting blow by, that is compression in the crank case. That comes past the rings. Either burnt/broken rings, or busted ring land.
Plan for an engine rebuild. In that list, put forged pistons and a head cooling mod.
CallSign_Cobra
Hahaha! Trust me I’ve already started comparing a Coyote swap vs a rebuild. Eventually I plan on building the motor after I found this out. I was just hoping to get at least a summer out of it before I put it away and tear it apart.
CallSign_Cobra
A leak down test was performed by the shop I took it to which turned out no good. I guess I’m just hoping it’s the rings being stuck since it sat for so long. I guess time will tell.
CallSign_Cobra
Yea like I said above. It was performed and came back no good. I’ve since pulled the plugs and added Marvel Mystery oil to each cylinder in hope that of it is something like a stuck ring maybe it’ll come loose and reseal. I’ve heard great results from this method and I figured I’d give it a shot. Going to let it sit for a few days and see what happens.
Zutz23
Don’t feel so bad man, my car was running mint last week, was out for a cruise with the wife and the. All of a sudden a timing chain jumps and takes out cylinders 3-4. Now I have to do a rebuild as well. I’m not mad about it because now I can build it the way I want.
I’m pissed because covid prices and lack of parts will out my car out for a year :( and summer just started.
white95
Apex Junky
Prairieville, LA
You have my luck it seems.
CallSign_Cobra
Hey man, trying the oil won’t hurt anything. It’s better to try it than just give up.
Yea. Definitely not giving up on it just yet. Just frustrated because I bought the car with intentions of enjoying it before I tore into it but it is what it is. Checked the oil in the cylinders today and 6 and 8 had a little in it and 7 had no oil. Poured a little more to let it soak some more. We’ll see what happens.
CallSign_Cobra
Yea that sucks dude. I guess it could always be worst right. At least mine is somewhat drivable other then one of the valve cover gaskets leaking which causes oil to drip a little onto the manifold and smoke. Just really can’t beat on it. I’ll replace that gasket and baby it until July when the car is due to go in to have the motor pulled. Good luck with the rebuild.
CallSign_Cobra
What’s up guys. Been quite a while since I’ve posted any updates on the car. Life happened. Lol. So after some research I found out that the gentleman who owned the car had an identical cobra motor stored away that he planned on building. Now this info is all coming from his wife as the gentleman passed away before he could do anything with it. So I got to look at it and sure as shit it’s a cobra motor. I’ll post those pics below:
So the motor allegedly was a prototype motor that was supposed to be part of a build that Ford was doing back in the late 90’s. The project was scratched and the motor was sold to the ladies husband. The motor was allegedly never run other then to be dyno’d and calibrated by ford. Now I’m not sure what a prototype motor is so if any can chime in please do so. The motor did have some parts labeled prototype on it which I’ll post below.
If you can zoom in above you’ll notice those red stickers say Ford prototype on then. Again if any knows what that may mean please chime in. I’ll continue this on a second post. Sorry for the long winded post.
CallSign_Cobra
So to keep this post a little shorter I purchased the motor and swapped all the goodies over to it. Car runs like a champ now. Here’s a few pics of the motor going in and of the car back home. Next up a few more go fast parts and off to the tuner.
Not sure if at this point I should move this over to a build thread but if so then I’ll start another thread for that. Thank you it’s for all the advice on the chat. Much appreciated. I’ll keep everyone posted on how the car does when it hits the rollers.
proto type is usually a specialty , one of a kind
like discovering plutonium
you could be a lucky man and have something really good
CallSign_Cobra
Well if that is so then I may have hit a home run with this one because all the parts on it had that same red sticker on them.
TreeScholar
