96 COBRA MIDPIPE->98 GT
rtgreen
Yes it will fit. I have a Bassani catted x-pipe from a 96 Cobra on my 96GT. You will not be able to use the GT supporting bracket, but I've had no prooblems letting the Manifolds and catback hold the weight.
:thumb:
Rantheman
+2 yeah there is now different between the midpipe and a catback of a gt and a cobra except for the 98 and new and older
19mustang95
scarface said:
i think he said..."there is no difference between the midpipe and a catback of a GT or a Cobra, except for the 98s and newer." :dunno:
Rantheman
oops let me try again. from 94-97 with midpipes are the same and so are the cabacks in 98 the midpipe was still the same but the cat back hangin was different does that sound any better!
96gt226410
By any chance would you guys know about mid pipes on the '03'-04 Cobras? Do they fit all 99-04 bodies? GTs? Mach 1s? Cobras? I have an O/R X-pipe off of an '03 Cobra I'm trying to sell and I was just wondering. Thanks.
scarface
Hanging is different. IM PRETTY SURE the 97 hangs from the muffler, the 98 hangs from the tailpipe just behind the muffler. I am using the hanger setup off a 98 on my 97 so I can switch back and forth from my magnaflow mufflers and my flowmasters quickly :)
A
AaRoN
King Post Whore
Well it fit!! Couldn't use the middle hanger but it's up just fine. Only problem is that the 2 "bitch" bolts that attach the midpipe to the passenger side manifold I can't seem to tighten so I am just gonna take it to a shop and have them struggle with them. Plus the predrilled holes for the o2's sit right under the frame support (support that's under the tranny) so i had to drill 2 new holes. Now my check engine light is on. But i think it's because those 2 bolts aren't tightened all the way. Car is ridicoulsly loud and pops when i let off the gas. Yikes. my car sounds like an old beat up Caddy or something.
whty98
On my 98 GT the exhaust hung by the muffler and the tips....on my stock muffs and Bassani cat-back. The 98 Bassani cat-back is the same as the ones used on 99+. I had a big issue w/ the company I ordered from and Bassani.
scarface
Ok, the reason I said that is on the magnaflow catback it fits 96-04. The difference is the hanger. I use the hanger style from the tailpipe not the muffler. Sorry if I spewed misinformation.
A
AaRoN
King Post Whore
Finally! Got the midpipe on. Work hasn't allowed me a whole lot of time. Everything is on, it's all sealed nice. It ALL fits. So yes a cobra midpipe will fit a GT. Only difference is the rear o2 sensor location. Had to tap 2 new holes. WOOHOO!!
Alida81
