(2003 Cobra bypass valve on SVO blower)
The boost bypass needs to reference air from before and after the blower. One line goes to the intake and needs to see boost. The other needs to be in front of the throttle body, in the cold air intake or simply open to atmosphere. Once you have that sorted you need to verify if it is functional? If it isn’t you will have a no boost condition without lots of throttle and then it’ll “come on” abruptly. It’ll also have sketchy low speed manners and get terrible fuel mileage. It’s easy to check, have someone start the car and watch the arm on the bypass. Start the car and the arm should open the valve, blip the throttle and it should close the valve.
If that doesn’t happen, it is possible you have a vacuum leak. You should hook up a vacuum gauge and see what she’s pulling at idle. This one was about $28-$29 at Oreillys Auto Parts. I don’t know about your specific bypass valve but the unit on my M122 needs 18 inches of mercury (in Hg) to open. Anything lower than that and it simply won’t open unless you’re really on the throttle. It would cruise around on 1# of boost. Sound familiar yet?
Do you have aftermarket cams? If so, they’ll add to the problem.
