You need a newer 5.4l alternator. Its case diameter is smaller. Probably gain you an inch of space.
I have a few alts layin around, try to get you size comparison pic.
Any chance of fabricating a sway bar spacer?
I made one for my rc car so I don't see why you can't for a full size . Although it would be a pain as you need some really stiff pipe and to get it done perfectly will be difficult.
Lookin' good!
Wasn't the mark8 alternator shorter as well? I know there were a few tbird people looking for a similar setup that needed a short alternator... The Allen s/c people maybe? Check tccoa for a search on short alternators, you might get some leads.
Draining coolant is always a pain in the butt. And every time you think it's empty, there's more. Swap going nicely!
Check your old gaskets and manifold, but I'm pretty sure that's a sealed passage. On the left bank it goes from the water pump to the thermostat.My wife helped me take the hood off and the extra room & light are amazing. Tucked some wires under the manifold and discovered that the rear coolant port (that goes into the heater core) isn't sealed off by the manifold base. The hose is supposed to be re-routed to the front crossover pipe, just wondering if anyone has any ideas how to seal off the coolant hole at the back of the passenger side head.
Sent from my iPhone using
EDIT: I discovered is just a hole that goes down to the valley of the top of the block. Doesn't look like it serves a purpose other than to contain coolant on top of the motor if your intake cracks. Not gonna worry about sealing it off
Sent from my moto z3 using Tapatalk
Since your not using your pi intake, would you sell it?? I can buy it today man
No. It's because the heads are universal castings. You only need to swap the oil galley plugs I believe.You're correct, after looking at it again it just goes straight down and is open at both ends. Doesn't look like it serves a purpose for head function, might have been used to hold the head during manufacturing or something
