Leo 5.0
Belt is new, I replaced that because it was old.
Thermostat works, I tested that during my radiator flush.
It took 9 flush cycles to get clear water...
Radiator is a common issue with the 96 and a 3 core is on my list of things to actually upgrade.
For now my concern is getting the pieces I have now to work.
I did check the connectors on the wiring harness, as mentioned nice and clean, most things that burn tend to either turn black or leave discoloring, these are still shiny, wires I unpinned from the harness and checked, then repinned, condition and connection is verified.
Coolant is less than 2 weeks old, 40/60 mix, with new Tstat gasket, stays at the Cold fill line where I had topped it off after burping it.
Thus far I am shooting for fan or sensor, in regards to money set aside for general maintenance, I am considering just revamping the whole system.
Overkill? Most likely, but a new fan, 3 core radiator, and sensors, would leave only the harness to blame, in which case another easy fix.
I have a rather large modding budget, but am only alotting 700 to the cooling system. I was trying to just fix it myself first so if anything should happen down the road after my upgrade, I wouldn't have to ask.
