96 GT Speedometer cluster electrical nightmare
moon96gt
Alabama
Hey guys, I am at a complete loss with my new-to-me 96 GT and its speedometer issues.
When I got the car, the speedometer, odometer, trip, and temp gauge were not working. The car had recently gotten a new clutch, so I assumed it was the vehicle speed sensor. I changed the sensor on the transmission and it still didn't work.
I took a test light to all the fuses under the dash and they were all working fine. So, I pulled my cluster and noticed one of the copper bands on the back was burnt(see photo) I also noticed a strange white powder behind where the cluster sits in the dash.
I bought a used, tested cluster from a reputable seller on eBay. Plugged it up and everything works now except the speedometer, trip, and odometer.
I then noticed my temp gauge on the new cluster was not going back down after the engine was turned off. If I unplugged the cluster, the temp gauge slowly went back down on its own, so I'm assuming it's an electrical issue. I'm not at all good at electrical work besides basic stuff.
Here is what I've done to troubleshoot the wiring:
  • Took a test light to all the pins on both the black and white cluster connectors. The correct pins lit up.
  • Unraveled the tape around the harness and didn't see any burnt wires.
  • Took off the driver-side kick plate and didn't notice any burnt wires.
  • Removed the factory radio and CD player to look inside with a flashlight. Couldn't see any burnt wires.
But here is where I am stuck now: I decided to re-test all the fuses under the dash, and now Fuse 13 is not lighting up at all.
I am at a complete loss. I reached back out to previous owner he said the temp gauge never worked since he owned the car and the speedometer stopped working a few weeks after replaced the clutch. Please help me with my next move to fixing my speedometer issues! What should I check next?
cobrajeff96
Germany
Well, the trans harness is prone to damage during trans removal/install. It's possible that the harness was chafed or excessively tugged on during their job. FWIW, it starts as a cube shaped connector on the passenger side firewall very near the heater core tubes (not the large cube connector on the passenger side firewall very close to the EVAP purge solenoid). Access to most of that harness is rather easy, especially with a lift. You'd only need to unhook it at several points in order to see any obvious damage, if any. So that's one thing to check and I say so only because of what you mentioned about previous owner's work and the coinciding of the failure.
Looking at your pic, that copper tracer is cleanly severed for sure. It's a small enough gap you could break out some soldering equipment and repair it, and then you'd have a spare because overall the rest of what I can see looks pristine. Alternatively, you can get an entirely brand new PCB (and not an entire used cluster) from National Parts Depot as I experienced a similar problem with a burnt tracer relatively recently. The multipin connectors sometimes don't cleanly line up with the tracers, and that sucks.
There are certain gauges that share a common power or ground circuit, and I do have documentation on that, but I'd say first go for the likely culprit and that's the trans harness. It seems a little too coincidental.
FWIW, I've only ever known my temp gauges to 'reset' upon key-on. In other words, once I shut the engine down after a drive, the needle stays put until the next key-on event some hours/days later. I think that's pretty normal behavior for an SN95 cluster.
96blak54
Staff member
Lawrenceburg Kentucky
@moon96gt you quoted "I'm not at all good at electrical work besides basic stuff".......Thats all of us!
You come to the right place though, because some here are really good with electrical and have most likely been where you are at right now and can help guide you. Just keep trying, take pictures, ask questions......youll figure this out.
Welcome to sn95forums
cobrajeff96
Germany
Luckily the SN95 was from a time when electrical systems were mostly simple anyways. The mid-90s just started to see solid state electronics in the American markets. The SN95 Mustang only has a few 'advanced' electronic systems onboard, namely the wiper module, the CCRM, and some others that generally don't require any thought or troubleshooting experience as they'll probably last forever.
moon96gt
Alabama
Update! I fixed it!!! After days or tracing wires, taking out the radio, driver's kick panel, glove box, driver seat all for it be corroded and burnt wires near the connector at the speed sensor
cobrajeff96
Germany
How'd that happen? Is there any obvious signs of chafing that could cause them to short together?
Lucky57
