D96V8Stang
- Joined
- Sep 5, 2017
- Messages
- 13
- Reaction score
- 0
Alright, before anyone says it, I have looked at other forums saying this issue could be the IAC, which I do plan to replace, after some input from you guys. My car has a heating issue so I thought it was vapor locking or something, but the fuel rails have pressure in them, and there's not a vacuum in the tank, both of which others have told me would be indication of vapor lock. Basically, I live in West Virginia, and I drove my car to a city in Ohio, about 150 miles away, and the car did fine...well as good as my car can.(I've wrecked it and pulled the condenser off for air flow to the radiator, which had been replaced because it was bent, all is good now though, sort of) After I got to where I was going in Ohio, the car started to have a rough idle in the neighborhood where I was staying at a low speed and low RPM. Then the next day I went to visit another friend that lives about 50 away from where I was staying. Getting there was fine, no issues. When I left after letting the car cool for 3 hours, I took off again, accidently left my a.c. on, which left the fan on, and the car heated up and stalled, but it didn't go above 210 the whole time. I plan on getting an egr block off plate and the new IAC valve, but is there anything else I should look into? Also think i need to replace the ccrm because my fan doesn't come on at the right temps(I think) and I've already replaced the manifold, temperature sensor and switch, and I have no other ideas.
