96 mustang gt sputters under load
Discussion in '96-04 - 2V Specific' started by sn95bythebay, Sep 29, 2016.
  1. sn95bythebay
    sn95bythebay New Member
    12
    Aug 22, 2016
    Recently my 1996 mustang gt has been hesitant under throttle (feels slow). If i give it throttle it sputters along and makes a humming sound especially when i go up a hill. What could this be? i read it could be the spark but i have new spark plugs and wires in the car. The coil pack been on the car ever since i got it. could it be a bad coil pack? Any info would help
  2. 98snakehorse
    98snakehorse Well-Known Member
    1,722
    208
    Oct 24, 2011
    Southeast, IA
    Could be? Could be many things, did you check to see if its throwing any codes?
  3. PinkieT
    PinkieT Well-Known Member
    1,764
    489
    Jun 22, 2015
    Cleveland
    Vacuum leak? That could cause the stumble, and the humming sound could be air being sucked into a place it shouldn't and vibrating the hose or something. Vacuum fart :tongue3:?
  4. sn95bythebay
    12
    Aug 22, 2016
    i checked for vacuums leaks and found zero. My car started to idle funny as well it will jump between 550 to 750 at idle
  5. sn95bythebay
    12
    Aug 22, 2016
    I have no cel at all
  6. 96blak54
    96blak54 Legend
    7,660
    993
    Feb 21, 2011
    Ky
    Make sure sparkplug holes are dry.
  7. Frank.JD.Perez
    Frank.JD.Perez Legend
    2,987
    254
    Sep 8, 2013
    Pleasanton/Hayward, CA
    *poors water into holes*
  8. Nighttrain
    Nighttrain Well-Known Member
    1,429
    Jun 10, 2016
    Atglen pennsylvania
    Could be any number of things, check fuel pressure vaccuum leaks, coils, maf may need cleaned, ect.
  9. JerZeyStangz
    JerZeyStangz Well-Known Member
    3,614
    39
    Jan 13, 2006
    Northern NJ
    I vote vacuum leak do to the age of the car. All of these cars are hitting close to 20 years old now and beyond. Now were seeing typical failures of fuel pumps, corroded rubber lines, etc...
  10. Jamie Barth
    Jamie Barth New Member
    Sep 27, 2016
    Columbia IL
    Just had a similar problem and mine was related to fuel delivery. Check fuel pressure.
  11. Nighttrain
    1,429
    Jun 10, 2016
    Atglen pennsylvania
    So im guessing you fixed this? Or now your problems have escalated?
