zyzygy said:Mine started doing that and it was a blown head gasket, when I bought the car it had a cracked radiator so I had a bronze one made, another cooling fix for 96 mustangs is to remove the grille in front of the radiator and if you notice 97 & 98's don't have a grille!
tajmas said:How do you make sure all the air is out of the system. Because I'm having problems with my '96. The only difference is I have a '99 motor in it. And am not sure how to check the fan with out taking the chance of overheating it again.
tajmas said:Did what you said DropTop, with cap off and heater full blast. A/f blew out canister, and I shut it off to cool, then I'll fill and do it again. I changed the cooling temp sending unit, and no a/f came out, but when I checked the thermostat, fluid was in the intake, but none came out. So I guess I just keep blowin' it, and fillin'. The fan hasn't come on yet, unless I turn on the a/c. And the temp gauge hasn't barely hit "N" on the gauge, even after letting it run for awhile. Idk?
tajmas said:Well according to the book I have to keep the cap off to bleed the air out of the system right?
