97tbird's……..2003 Mach 1
97tbird
Plainfield, Illinois
2003 Mach 1:
IUP package
5-speed
Zinc yellow
I bought the car in 2012 w/ 34k miles. Really had no intent to mod the car.
Motor:
Stock
Exhaust:
Jet hot coated Kooks 1 3/4" primaries to 3in collector
Kooks 3in catless x pipe
3in dynomax bullet mufflers dumped before axle
Transmission:
TKO600 w/ MGW shifter
Ram power grip clutch
Stifflers driveshaft safety loop
FRPP flywheel
FRPP aluminum drive shaft
Rear end:
FRPP 4.30 gear
FRPP diff girdle
Strange 35 spline axles
Strange spool
Welded axle tubes
Swarr bar
Spherical housing bushings
Suspension:
UPR tubular k-member
MM caster camber plates
UPR coil overs up front w/ strange 10 way. 14" 175lb springs
MM rear lower control arms
Rear strange 10 way shocks
MU rear lowering springs
UMI upper control arms
UPR upper torque box plates
*coming soon-
maximum motorsport sub frame connectors
Brakes:
Drilled/slotted fleebay rotors (Mach 1's came factory with cobra brakes)
Wheels:
Drag set up-
Weld rt-s s71
Front 17 x 4
Rear 15 x 8 (m/t et street 27x10.5)
Street/Strip set up-
17x9 cobra reps with 275/40 tires. Rear are m/t et street
Street set up-
Stock Mach 1 wheels 17 x 8 245/45
Interior:
Weight reduction
Corbeau CR-1 seats
Rear seat delete
Exterior:
Tinted windows (unsure of %)
Plasti-dipped deck lid (for now)
Hood stripe delete
V6 rear bumper
*coming soon-
03/04 cobra side skirts
Wing delete decklid
97tbird
97tbird
Cpotts13
Biloxi, MS
very nice... love the color.. What are the plans for it? Have you dynoed it yet?
97tbird
97tbird
Its just a fun "street" car that… might have gone a little over board on it
On motor un-tuned with stock manifolds and a catless x pipe the car made 310hp/330tq.
Haven't gotten it back on the rollers with the long tubes or to get it tuned.
97tbird
97tbird
Well the rear end is getting built sooner than I had expected. Broke it at the track this weekend. Car is at the shop and the rest of the parts needed for the build are in route.
marktuck99
