For the longest time (4 years or more) I have been looking at, and loving the way the cobra brake caliper bracket in the rear looks in the rear. I love how the two ends that hold the slide pins connect on the outside. I thought the v6/gt look wasn't finished and looked bad. Well i bought the 13" baer upgrade kit and it just started to make the caliper more visible and made it more of an eye sore to my eyes. So i went did some research online and found some answers but not everything i wanted to know.
The answers i found were about the calipers from v6 mustang, to GT mustang, to the Cobra on the rear are all the same. How ever the cobra brake pad, is different compared to the v6/gt. The cobra pads are thinner and the cobra rotors were larger compared v6/gt in the rear. This concerned me because i thought the cobra caliper bracket would be taller to accommodate the larger rotor. But there happens to be a larger mounting plate that bolts to the axle housing behind the axle. That is where the caliper bracket mounts to.
After finding that out, i decided to check out the caliper bracket out myself.
From what i found out from above i decide to go look for myself in the parts store. I put the v6/gt bracket next to the cobra one and looked pretty hard at the two items. in the store. After looking them both over, the best i could do is eye ball the two because i do not own a caliper tool lol. But the things i did find out after eye balling the two brackets
The Distance between the slide pins are the same (given since the calipers are all the same).
The distance between the slide pin and the hole where the bolt goes through on the caliper bracket. This meant to me the brackets were in fact the same height and it was indeed the two could be interchangeable.
Lastly the distance between both bolt holes were the same. Great news! This mean the brackets were even more simular.
As i bought the one bracket I found out the dust cover for the slide pins were smaller than the gt/v6 ones
I forgot to bring a bolt with me to see if the thread pitch was the same but i checked when i got home. The new bracket that helps adapted the 13" rotors used their own special longer bolts. But same thread pitch, So i had the stock bolts left over. And good news
So now i wait for the weather to get a little warmer aswell as wait for the other bracket to come in so i can add both of these at the same time.
