Slykin
First off, for the very few people that recognize me.. i'm back.. It's been years since I've been on here or been in the mustang scene. But anyhow, on to the A/C problem.
I recently charged my A/C because it was low and blowing hot air. After charging, it was blowing frigid cold air. Awesome. It's finally fixed and working. The problem occurs the very afternoon I charged it.. that very evening(a couple hours later) I went to drive to the grocery store and the A/C was blowing straight up hot air. I automatically figured that it had a massive leak and I just needed to change o rings and recharge.
Well, the next day I drove to work and it was blowing ice cold air again. Got done with work expecting the A/C to be working... but it started blowing hot air again after about 10min of cold air. Decided to check the freon levels again but the A/C clutch won't engage. I tried jumping the low pressure switch and the A/C clutch won't spin. Needless to say, i'm confused. It appears that my fuses are fine too, but I have no idea if the CCRM is good/bad or if I should even check that first.
CHECKLIST:
Jumping low pressure switch doesn't work
Low Side Pressure with compressor off: 110PSI(90F Ambient temp)
High Side Pressure with compressor off: 100PSI(90F Ambient temp)
Fuses Good
Blows Cold in the morning for one 35min drive and gets hot after 10min of driving in afternoon
Any help would be appreciated.
CHECKLIST:
Fuses Good
