a-c pillars?
Are there bolts on the underside of these or are they just clipped in? I have never removed them and need to now for my next part of the project. Thanks in advance.
g36 monkey
Orlando, Fl
They are bolted in. The sail panel has like 8 studs on it I believe, you access them from the rear. If I remember correctly the front panel has to have the weather stripping and the rail removed and there's 3 or 4 Phillips head screws under it.
excellent thanks. Way too cold to consider taking them off now and there are supplies still being shipped for this project anyway.
Tally_4.6
Orlando, Fl
Apillar has to be removed to remove the rear.
Along with the weatherstripping and the rail piece like jeremy said.
Sent from tha trap house.
Finally got around to this tonight. Is that weather stripping rail glued in or something? I have all the screws out and tried pulling on it and it was not budging at all...
I pried and pulled on them as hard as I was comfortable doing with out knowing for sure that was the correct part.
I have not taken a look at it since late last night. 3-4 days ago I didn't sleep at all one night and since then I have basically been nocturnal. Going to go out in a few to look at it again.
rvseverson
