A peak at whats going on!
95opal
95opal
Final assembly is underway.
new one piece hardend pushrods
comp cams ultra pro magnum chromemoly rockers
ready to start setting valve lash
valve lash set intake gasket mock up
boom intake on and torqued to spec
Had to notch the valve cover to clear the blower intake elbow. Hopefully finish polishing them up and installed over the weekend.
And a better pic of the smoothed cowl Im patiently waiting on to return from my painter
With a little luck I will have this motor wrapped up this week and start to fully concentrate on the interior fabrication.
Tony
ohio
looks awesome man that intake is polished to the max lol. are the v/c's black on sides polished on tops?
95opal
95opal
Used to be polished to the max, I had it chrome powder coated for ease of maintenance. Yes the covers are black and polished, see below
evilcw311
Most Evil Member!
Louisville, KY
That pic.................
..........I need a towel.......... $-)
I've heard the chrome powdercoating doesn't hold up particularly well compared to other powdercoating finishes. I was wanting to get a lot of stuff on my supermoto build chrome powder'd but was a little nervous about it but if you're putting it on this car, then I think I may have to rethink my plans because I'm getting tired of polishing little bits lol.
95opal
95opal
Which headers are you using? They appear to have good clearance and the 3 inch wide bolt pattern.
The headers are modified BBK's that I had ceramic coated
Damn, I'm excited!
Don't get to excited still battling some clearance issues but I do have them sorted out now. Just had to do a little reworking of the driverside valve cover lol
I haven't heard of any real known issues with the chrome powder compared to other colors. I do know from previous things Ive had coated that any type of cleaner besides soap and water will kill the powder. In my case I went with the chrome powder because polishing that lower intake constantly would be the death of me. If the powder fails I can simple pop the lower off and have it repowdered. Not ideal I know but sure beats trying to keep all those small pockets and curves polished on the lower.
g36 monkey
Orlando, Fl
Hopefully that chrome holds up then! And man there will be a lot of little things that hem up here and there but it's coming!
95opal
95opal
Only time will tell with the powder, not really worried about it. Always a ton of tweeking , it never ends lol.
Anyway cover is back in one piece and I re sprayed both of them last night so that issue is over on to the next lol
95opal
95opal
Mile stone reached,,, all wiring and plumbing complete in the bay just waiting on my painter to finish up the firewall cover, rad cover and cowl panel and we can drop the hood on and close it.
g36 monkey
Orlando, Fl
That looks incredible! Try to get some shots of it standing back so we can see it in all it's capacious glory!
The question is, have you started it yet?!?
95opal
95opal
Tew I was trying to show the injector wiring and modified valve covers lol. Ill post complete pics once all the panels are in and right now my painter is holding me up on that. As far as starting her im still a bit away from that as i need to wire up the fuel pump, fuel pump controller and water pump. All that is on hold till I can complete the center console that will house the switch panel for all that stuff. So your going to have to wait on the start up vids for a while as I just started making the templates for the console. I have about a month to get shit done before I head yourvway for the winter. More than likely it will be an early summer start up as theres no way i will be getting everything done that is needed to start her up before I leave. I also need to get a start up tune as im a but worried these 80# injectors will wash the cylinder walls if i try to get it running on my old tune. So hang in there a little longer lol
95opal
95opal
bye bye pinion flange hello moser pinion yoke
stifflers safety loop
all buttoned up
custom shroud installed
clutch cable dress up
running wires
started on my analog clock pod.
TN95gt
