Is anybody familiar with doing an ABS delete? I took the ABS pump off the other day and that thing has some serious weight to it. I've saw some posts elsewhere about using a ABS delete manifold so you don't have to plum new lines. Worth it? It would sure make things cleaning without having that big unit mounted up front. I don't think the ABS functions can be shut off at the ECU, so I assume the light would always be on and would warrant removing the bulb from the cluster.
