My AC compressor won't engage so I have non functioning AC for the moment.
Heres what I checked:
-Physically turning the clutch by hand to make sure it isn't locked up; it wasn't.
-Checked low side pressure. It was actually over 160psi so I bled some out now it's at about 40psi
-Jumped the low pressure switch and it still didn't kick on. It just changed the idle the same way it does when I turn the AC knob inside the car.
-Verified that the 15A fuse under the driver side compartment isn't blown; it wasn't.
I have not jumped the high pressure switch nor have I tested the psi on that side. I also haven't checked the relay or ccrm I think it's called.
Can an I get any advice here? Is there anything else I should check or is that basically all of it? Also of the list of items I haven't tested yet, which one seems most likely the fault?
