Ac on car stalls.. working IAC
Discussion in '94-95 5.0 - Specific' started by the5.ohh, Aug 8, 2016.
  1. the5.ohh
    the5.ohh Legend
    9,555
    108
    Oct 15, 2012
    Shaolin, NY
    Ever since I did the HCI swap I've had this issue. Ac on, car will stall coming to a stop, and even in first or 2nd gear slowing down. Car has a dyno tune on it, I was able to use the AC on the way home but that was about it.. IAC is working, tested that. Unplugged it, car stalled, so it works. I bumped up the idle a little bit, it idles, but as soon as you rev it, idle drops all the way down and she stalls. Turn it back on, AC off, and it struggles to idle, rpms go up and down, and unless you gas it, it stalls. Ac compressor works fine. I'm ready to torch it. Somebody help.
  2. the5.ohh
    the5.ohh Legend
    9,555
    108
    Oct 15, 2012
    Shaolin, NY
    And before anyone says it, no I'm not deleting the AC. I like to be comfortable when I drive, and so do my passengers. Haven't been able to use AC in over 5 months. I'm just done with this car lol. Always something.
  3. the5.ohh
    the5.ohh Legend
    9,555
    108
    Oct 15, 2012
    Shaolin, NY
    I should add that it stalls in reverse too, every time.. rev it up and roll back, shuts off.
  4. Nighttrain
    Nighttrain Well-Known Member
    1,429
    Jun 10, 2016
    Atglen pennsylvania
    Iac restrictor plate, maf clean? What cams did you go with? Fpr? Hows the fuel pressure?
  5. the5.ohh
    the5.ohh Legend
    9,555
    108
    Oct 15, 2012
    Shaolin, NY
    Don't have a restrictor plate on but I guess you mean try one out? Maf is clean, Trickflow stage one cam, kirban adjustable fuel pressure regulator. Fuel pressure is good. I called the tuner and he said I can bring the car in and they'll check it out for me. I don't have the time at the moment.
  6. Nighttrain
    1,429
    Jun 10, 2016
    Atglen pennsylvania
    Yea try one. What are the numbers on the cam. I doubt this is the case with a cam they label as stage one but if the cam isnt creating enough vacuum you will have idle issues. Whats the regulator set at
  7. the5.ohh
    the5.ohh Legend
    9,555
    108
    Oct 15, 2012
    Shaolin, NY
    Cam Specs
    2,000-5,500
    Intake Duration at 050 inch Lift: 221
    Exhaust Duration at 050 inch Lift: 225
    Duration at 050 inch Lift: 221 int./225 exh.
    Advertised Intake Duration: 275
    Advertised Exhaust Duration: 279
    Advertised Duration: 275 int./279 exh.
    Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
    Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
    Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh.
    Lobe Separation (degrees): 112
    Camshaft Gear Attachment: 1-bolt
    Computer-Controlled Compatible: Yes
    Grind Number: HR-224/339-2S-12
    Valve Springs Required: Yes
    Lift w/ 1.6 rocker (intake/exhaust) - .499"/.510"
    Lobe separation (degrees) - 112
    Forgot what the fpr is set at.
  8. Nighttrain
    1,429
    Jun 10, 2016
    Atglen pennsylvania
    That cam isnt wild lsa's not crazy either. Even if you put 1.7 rockers on it wont increase your lift too much. Hmmm
    Coil ok not cracked? Do you have aftermarket dizzy? You might have already said this..........vacuum test, check your evap system make sure the canister isnt cracked and lines are good.
  9. Nighttrain
    1,429
    Jun 10, 2016
    Atglen pennsylvania
    This isnt an ac problem. Somethings dropping your idle, so basically either, vacuum or fuel pressure. But you said fp is good. Could be spark, like a cracked coil or bad distributer but youd have a miss in it more than likely.
  10. the5.ohh
    the5.ohh Legend
    9,555
    108
    Oct 15, 2012
    Shaolin, NY
    Still rockin the original dizzy, coil seems fine. I'll have to look into the evap stuff. Yeah its not a crazy cam so thats why I'm skeptical as to whats going on ya know.
