i just got done putting the battery back to the front of the car because it was a hassle in the trunk. now the air bag light is on.?? any ideas and feedback to wat i need to do will be greatly appreciated.
loose connection somewhere. i had this problem once upon a time. re-check all your connections and fuses.
wat connections?? and i just checked the fuse and one blew then after i replaced it i started the car up and it was on again.
how old is your battery? check the cables (ground & power) going to the battery itself. make sure they don't move when you wiggle them. also check any wires going to each fuse box.
