All four calipers won't release
joeybuddy96
KY
I've posted in detail the current situation on another forum: https://stangnet.com/mustang-forums/.../#post-9465403
Here's the summary though:
  • The problem: brakes won't fully release, even when driving above 60mph, causing pads to wear out and shuddering vibrations. I'm pretty sure even if the vibrations are caused by something other than the brakes, the brakes probably still aren't releasing because the pads have worn out so quickly. It was fairly difficult to compress the front pads with a C-clamp; I wasn't able to fully compress them, but that's probably because I didn't open the bleeder valve. Getting U1043 and C1165 error codes with ABS and trac control lights on.
  • What I've already done: a bunch of stuff. Recently, swapped out the ABS module/hydraulic distributor with a salvage yard unit and installed a new master cylinder.
  • Possible solutions: new flexible brake hoses, do more electrical system diagnostics, and/or mail it to someone who can inspect and repair the original ABS module. Another forum suggested air could be trapped in the ABS module, but I've already changed out the module and bled all four calipers, so unless air got trapped in *both* units, I don't think that's it. Idk how to bleed the hydraulic distributor if that's the case.
I'm really almost completely tapped out of ideas. There's a finite number of parts in the brake system, so I don't know how it's possible that the brakes still won't release.
cobrajeff96
Germany
It's unlikely air is trapped inside the hydraulic unit. If you feel the need to send it in, there's outfits that can inspect it.
You ought to try opening up the caliper bleeder screws in order to bottom out the pistons. The M/C should have a bleeder screw on it as well and it's worthwhile to bleed it as a normal part of brake system maintenance.
Any pics?
you are supposed to bench bleed the abs unit prior to installing it, and then I think after as well. There is a way in the ford computer to do it. I had the opposite problem when I had air in mine and could not find anyone that could bleed it and read if you can get the abs unit to activate when the wheels lock up that it does the same thing. I found a dusty area in a parking lot and locked it up on it and felt the abs kick in, after bleeding the brakes again then it was fine.
J
joeybuddy96
KY
Any pics?
I installed the salvage abs/hydraulic distributor, bled the brand new MC, then bled all four calipers.
Is the idea behind bottoming out the pistons that that would to get them to a new zero state that they'll return to every time? It seems like the calipers ought to be doing that anyway, and that the only thing that'd change is the volume of fluid in the reservoir. I didn't compress them all the way down when I did the whole bleeding procedure. I guess the order of operations in that case would be to bleed all the air out of all four of the lines, (in which case the brakes at that point would be clamped down on the rotor almost completely), then crack the bleeder on one again, completely compress the pistons down as far as they'll go on that same one, reattach the caliper, repeat for the other three, and take it for a test drive.
Pics of what?
J
joeybuddy96
KY
Before this issue occurred, did the car ever drift to one side when you hit the brakes?
No, not noticibly. Maybe a little wobbly. The steering has always felt sensitive with a slight drift to one side, even after I centered the steering column and rack.
cobrajeff96
Germany
The reason you'd bottom out pistons is so that the pads will properly clear the rotor before you do the bleed procedure. Otherwise, the residual tension is a bit too much and the wear accelerates early on, needlessly.
J
joeybuddy96
KY
@cobrajeff96
I used just the regular brake pad method of bleeding the air out, so it sounds like I'd have to have the pistons secured in their bottomed out state prior to bleeding them. In that case, it sounds like it's not too late for me to do that after I've already bled them. I should probably get a brake compression kit to make it easier.
cobrajeff96
Germany
Certainly makes it easier. But bear in mind the rear calipers need a kit that turns the piston the same time while compressing them. It's what the two indentations are for on the face of the rear caliper pistons.
white95
Apex Junky
Admin
Prairieville, LA
Only asking to determine caliper health. Sticking pistons could lead to strange braking antics and potentially this issue you're having.
cobrajeff96
Germany
I do have fond (not so fond) memories of those front caliper slide pins galling and sticking. So glad I went to fixed mount calipers many years ago.
weendoggy
I did go to the other forum to read what you've done. However, one thing I don't see is you actually changing the flex hoses (rubber) to the caliper's. You may think they look good from the outside, but, the inside is what may be causing your issue. Hoses deteriorate from the inside, which you won't see and cause fluid to NOT flow back to the MC, which then holds the caliper in a slightly applied mode, even though your not applying the brakes. I highly recommend you put some good NEW hoses on all four brakes, bleed them with a pressure bleeder and then test. I do also agree with making sure ALL the slides and/or mechanical functions of the brakes work smooth. You also need the pistons to move freely and some can, over time, build up a ridge (so to speak) in the caliper bore causing a "hang up" condition. That is not my first thing to attack though, I'd do hoses. Also, make sure all your ABS rings and sensors are clean and spaced. Many cars can run without the ABS module so I doubt that's the problem. Sometimes you have to do the basics before trying to find the problem and a lot of times, you find it early.
J
joeybuddy96
KY
@cobrajeff96 @weendoggy
Got the brake compression kit and compressed all the pads today. The calipers all came off fairly easily. Both front ones weren't difficult to take off. I just used a pry bar and shimmied them off. None of any of the pistons were stuck or seized up. The front right ones were more difficult than the front left ones to compress. Might have been becaue I had the bleeder bottle set up wrong on that one (tube goes from the center valve to the bleeder valve, folks). The brake pads on the front right are worn almost down to zero, and the front left ones have like 10% wear left.
Both of the rear pistons were the most difficult to compress. Not sure why that is; might be because they have a single turning piston and a bunch of other parts inside. The pads on those were fine. A couple months ago, one of the caliper pins on the rear right side had seized up, so the wear on that rotor was less even and the pads were less symmetrical, but it's not worn out more than like 10%.
About four months ago, I took off the front right caliper completely and removed both pistons bc one of the pistons wasn't compressing, even with the bleeder valve open. I got that piston back in place with a new seal around it. I dinged it up some, but it compressed as well as the other one in that same caliper did. The bores looked smooth, without any raised ridges.
The right rear brake sensor looks as good as it did last time I checked it, so idk why it'd be throwing the C1165 error. The plastic is broken that holds it in place, but it's crammed in there and doesn't need that piece, but the electronics aren't exposed. I'm going to get a new one anyway. The other sensors looked fine, had space and everything. I could've cleaned them up some, but I know from testing just their resistance that they're at least passing signals to the harness.
All the slide pins on all the calipers were still moving fine, still greased up from the last time I worked on them. The green caliper grease from a tiny tube I'd used last time was gone, so I put more of it on the slidey shim thingies and the pads' ends. Idk if it'll hold up, seems like the weather probably just washed it all off.
So far, I know for sure that my shopping list will include: front brake pads, o2 sensor (see other thread for that battle), front and rear flexible brake hoses, and right rear ABS sensor.
Now my question is what else should I change out? Going just by the pad wear on the front, seems like those hoses are bad at least, but should I also change out all four of those pistons or leave those alone or just do the two right front pistons, or change out the entire front right caliper or leave it alone? Change out the rear calipers? Calipers aren't super expensive at the lower shelf /refurbished end (about $50 to $70 each if I buy them locally and do a core return) but they ain't cheap, either.
cobrajeff96
Germany
It's really a judgment call based on budget, time, and how bad you want to keep the car moving. I can't really tell ya which option to choose from. But it seems you have a good handle on the problem and the brake system as a whole.
weendoggy
You say both rear pistons were hard to compress? Are you using the correct tool? A "C-clamp" is NOT the correct tool. You need a special one that turns the piston back into the bore. This was mentioned before. If you pressed them in, you may have already damaged the E-brake/screw/adjuster inside.
At least do pads, hoses and the sensor. Clean it and run to see what happens. I use a antisieze instead of grease on the slides and moving parts. Like Brylcream, a little dab-l-do-ya. No need to slop it on. Keep it, and anything else you use, away from the pads and rotors.
J
joeybuddy96
KY
@weendoggy
Yeah, a caliper piston compression tool I got off Amazon. The #6 thing with the two studs on one surface worked for turning in the rear pistons, and the "O" pad (just a big flat circle that attached to the tool) worked for the front pistons. The rear ones weren't super hard, but it did take effort, even with the bleeder valve cracked open. Maybe like 25-35 ft lbs of torque, but I wasn't using a torque wrench to measure it.
@cobrajeff96
It's my only car. I'm just trying to make the brakes stop trying to stop the car when the car is supposed to be going, and to get the vibration/shuddering above 60 mph to stop. I'm not really looking to convert it to a race car or smth, I just want to fix the problems without continually spending more on shipping when a given round of guesswork or attempts doesn't end up addressing the core issue.
weendoggy
Be sure to check both driveline u-joints, tire balance, true rotors, true wheels etc for any vibration issues. I know it's a lot to do, but worth it in the end. A lot of things can cause vibration at speed and you just have to start the elimination of items (not saying to replace them) that may be adding to the issue. Be aware that your brakes will seem to drag when the wheel/tire is off the ground.
J
joeybuddy96
KY
@weendoggy
Got both the u-joints swapped out, tires are balanced, idk about the rotors, aside from the right rear being worn down some, it looks fine. The stuck pin possibly could've warped it. The other rotors look fine, but without a precision tool to check for wobble, that's an unknown. The rims on some of the tires are dinged up some, so that could possibly cause vibration, too. I'd be looking at another several hundred dollars for new rims if that's the case. The vibration doesn't seem to change depending on which tire is where, so it's less likely.
cobrajeff96
Germany
Did you adjust the rod from the brake booster to the master cylinder? Maybe it’s too long keeping constant brake pressure. Loosen the Master cylinder nuts and see if anything frees up.
That's a good point because if your swapped component is not period-correct for the exact model year, this could spell problems. I crossed this gap in recent years when I swapped an m/c reservoir and a booster outside of what was fatory original, and luckily I had the correct 'bullet nose' spacer to go between the hydroboost power rod and the receptacle of the m/c. Preload coming from a hydroboost power rod will always actuate the caliper pistons as mentioned and make the application of the in-cabin brake pedal extremely touchy and kind of dangerous.
Also check your wheel bearings (really the front ones) for any play by grabbing hold of the tire at 12 and 6 o'clock positions while jacked up and aggressively pulling and pushing inward/outward, looking for obvious play of the wheel in relation to the spindle/brake caliper and control arms. There should be zero. You can also see bearing slop by simply rotating the wheel while checking the runout between the ABS tone ring and the ABS wheel speed sensor.
Lucky57
