All four calipers won't release
J
joeybuddy96
KY
I can't remember too well but did you check for bearing play? I ask because the clearances involved between the VR sensor and the tone ring are toight. Rust, gunk, corrosion, etc. will potentially effect the module's ability to get good readings too. It could be that simple.
No, I forgot again, lol. I'll have to check it when I'm doing all the brake malarkey this weekend. I've checked the gaps between the little metal stick things and the tone rings to make sure they're not scraping it. Afaik there's not a specific gap distance.
@weendoggy Yeah, a mityvac would be a lot more convenient. I had to keep walking back and forth between sitting in the driver's seat and a caliper a million times to determine if fluid was moving or not. I had to look to see if there were any bubbles and if the level of fluid in the bottle had risen. When the bleeder screw was open too far, new bubbles kept appearing one after another. I think that maybe having someone else depress the brake pedal all the way down as far down to the floor as their leg muscles can would allow the vacuum to pull the calipers back apart, which might help with the whole problem of the calipers not releasing.
The ABS codes might be caused by lack of pressure, I guess. The codes are the same C1235 and U1043 ones I've been getting. I'll have to check and see if the manual references which code goes to what, but I think the C1235 reference goes to the right rear one I replaced. I think replacing that one has helped some, since the codes don't appear for like ten minutes after I've reset them and have driven around. So again, maybe it's wires or connectors, but electrical problems seem to be a nightmare not many mechanics want to dare to touch.
you make it sound like you are bleeding them on your own? Do you have the hose going down into a full bottle of fluid or how are you doing this?
J
joeybuddy96
KY
Yeah, I did it solo. I'm going to get someone else to at least do the final brake depression before I close off a bleeder screw. I plan on getting all the air out of all four first and then get someone to do that final pedal push. The bottle hasn't always had a lot of fluid at the bottom, but even if air got sucked up initially, I'm pumping the brakes enough that the bottle is at least half full, which should probably be purging out that initial pedal push. I'll fill it like half full before starting next time, though. This is the bleeder bottle I've been using; it has a check valve anyway, but maybe that's not enough.
J
joeybuddy96
KY
Do I need to do the thing with compressing each piston when bleeding it this time around? I watched a bunch of videos and they all just bled them with the calipers in place and didn't mess with the pistons.
cobrajeff96
Germany
Not necessarily. Bottoming the pistons is what's needed when you put new rotors on, in order to clear the increased thickness of new rotors. Once everything's installed, you bleed as normal.
J
joeybuddy96
KY
I worked on the brakes this weekend. I replaced all four flexible brake hoses and all four front pads. I ended up having to splice both of the rear hard lines, bc they both broke when I was unscrewing the bubble fitting. One of them seemed like it was unscrewing fine, and then the line just snapped. I used a Titan brake line tool and some new fittings to fix it.
I replaced the rear right caliper last weekend, and tried to replace the rear left one this weekend. The rear left caliper piston's seal failed and started leaking as soon as I turned the car on and pressed the brake pedal to test it. It's a remanufactured caliper. I think I might be able to return it for a refund. I put the old one back on. Idk if it even needs to be replaced. I figure if I don't, next time I take the car to a mechanic, they'll just blame the part for any problems and I'll end up having to replace it anyway. The old one still works, as far as I can tell. Idk why the newer caliper piston failed--I had the indentation lined up with the bump on the pad and everything. As far as I can tell, the entire rear braking system is dependent on a little nub not wearing down by a fraction of an inch or on the piston skipping over the nub. In the case of the pads I've got, it appears that the pad's ceramics have outlasted the nub by at least several thousand miles. The outside pad also has a teeny tiny bump on it that hasn't worn down as much from when I swapped it with the inside one several months ago, but hasn't been without wear relative to the unused bumps on the top and bottom of the pads.
I checked the right rear wheel for bearing play, but all I noticed was the movement of the rotor that the brake caliper allows. I forgot to check the other wheels again. Next time I'll check for sure, though. I replaced the rear axle bearings several months ago in an attempt to fix the shuddering vibration that starts at 60mph. The front right bearing was replaced before I bought the car last year.
I replaced the two phenolic pistons, boots, and seals on the right front caliper. When compressing the pistons, it felt like they were still not sliding in as easily as the old front left ones did. Like maybe the piston chambers are out of round or smth and the pistons are jamming up or scraping the sides of the chambers. The left caliper pistons compressed without much resistance, aside from the friction from the seals.
The problem with both front calipers is that the bleeder screws are both rounded off. It's partly from rust and using wrenches instead of deep hex sockets. That means I'm pretty much unable to bleed the air from both front lines. I've tried to use a variety pack of screws, but even though they have the right thread pitch, they're too short for the calipers, so they don't seal the bleeder screw socket off. I could maybe ask the manufacturer if they have replacement screws, but I think maybe with the right caliper potentially sticking, it might be an okay idea to shell out $140 to replace both (that's factoring in the core charge).
The mushy brakes have been resolved. I got a second person to do the holding-the-brake-pedal thing. I'm just not going to be able to do that again bc of the ruined bleeder screws. I kept the MC reservoir filled the entire time I did everything, including splicing the rear left brake line.
The C1235 and U1043 errors kept popping up even after all that work. C1235 is a rear right sensor mismatch. That's the sensor I just replaced. My first suspicion is that it's a bad wire. The area underneath the rear seats keeps getting pooling water, so duh, ofc that could harm wiring, even if the harness has insulation. The water is coming in from the back window. The soft top doesn't seal at the edges. Water pools in the trunk, under the rear seats, the carpet everywhere, and water drips from the front left corner where it meets the windshield. Might be partly from clogged weep holes, too.
Even after I've cleared out the codes, with no ABS dashboard light lit up, I can hear the front left tire make a skidding noise when I tested out the brakes during a test drive. So maybe it's the front left sensor that's bad and the computer is just refusing to display that code. Maybe it's something to do with the caliper. Maybe one of the computer modules. I think if the front left ABS and the rear right ABS aren't working correctly, it could mean the car will go in some random direction if I have to suddenly slam on the brakes above 30mph.
The vibration is still there above 60mph. I keep chasing the source of it. I think mechanics are going to keep blaming the brakes and won't try to investigate it unless replace everything. My shopping list could potentially include:
-Both front calipers
-All four rotors
-A different rear left caliper
-Rear brake pads
-Front left ABS sensor
Any thoughts on what I should or shouldn't buy next?
cobrajeff96
Germany
I would still say verify by hand that the wheel bearings (especially the fronts) have no free play.
Is this vibration felt through the steering wheel or the seat (through the floor pan)? Or both?
J
joeybuddy96
KY
Both. You can hear the plastic interior panels shaking when it's going on.
cobrajeff96
Germany
Just gotta check everything from bearings to suspension bushings, anything that moves or has potential to move.
J
joeybuddy96
KY
I checked both rear wheels yesterday. They shift around a lot, but that's just from the calipers moving, as far as I could tell. I've already replaced all four shocks, the front control arm bushings, sway bar links, driveshaft U-joints, castle nut on the differential-side yoke, both rear bearings, bushing on the transmission extension housing, and inner and outer tie rods. I'm running out of things that can potentially cause the shuddering.
I haven't finished replacing the brake-related stuff, so that's still on the list of potential causes. Rims, driveshaft imbalance, engine or transmission somehow starting a chain-reaction of vibrations, maybe the suspension springs are laterally asymmetrical with each other (i.e. one side of the car higher than the other), or the entire frame of the car is warped.
cobrajeff96
Germany
If the frame is warped, more than likely the car can never achieve a wheel alignment. Especially when it comes to the Thrust Angle. So unless your alignment shop either can't get it right or refuses to serve you, probably rule that out. It's really only things that rotate that you gotta inspect as a first priority.
weendoggy
Can't find if you actually had the rear end/axle assy checked. When you feel the imbalance, is it constant under throttle or deceleration. I ask because I once had a bad vibration/hum at speed which turned out to be the pinion bearing and actually snapped my pinion in half on the highway. Do you feel it more in "seat of pants"? For all that you've done to eliminate balance/vibration issues, I wouldn't rule out rear end noise. Not sure what you mean by the rear wheels moving around a lot either.
J
joeybuddy96
KY
It's in both the seat and steering wheel; you can hear the interior trim rattle. It's under constant throttle once it hits 60mph. The shuddering has a rise and fall pattern: rises, plateaus for a few seconds, falls back down to absent for a few seconds, rises back up, etc.. In attempting to fix the vibration, I've changed out the nut on the differential, the seal on both ends of the driveshaft, both U-joints, and the rear axle bearings. None of that helped at all. What I mean by the rear wheels moving is that when the car is lifted on jack stands, the calipers and rotors are supposed to be able to move around some, so if they weren't moving, that'd mean a seized piston, pin, brake pad, rotor, etc..
So, yeah, it *could* be a rear axle, coil, etc., but when I'm listing the parts, I'm not necessarily coming up with a good theory for why a given part might be causing the cyclical shuddering. I keep making educated guesses at this and buying parts that don't fix the shuddering. I bought about $307 worth of parts this weekend for the brakes, so maybe that'll help with the vibration, but I think it's more likely that'll just help with the calipers being stuck.
just out of stupidity because it happened to me on my first truck, run your hand on the inside of each tire all the way around. The side you can't see. I had a crazy vibration that sometimes would seem like it was going to turn right off the road, others it was just a light vibration and sometimes it was gone all together. When I finally got it in and they had it on the lift you could easily see that one of the front tires had the steel belts fail/slip and there was a bubble that had formed inside. Even on a ranger with all the space with stock wheels/tires(15" I think was on my 90 ranger) you could not see it and because it was a front tire under braking or while not under acceleration it wobbled but when I gave it a little gas it did not effect it.
J
joeybuddy96
KY
I forgot to mention that all four tires are new; the vibration preceded getting them changed out. I've looked at both sides of the tires since then. The rims are dinged up, so it could potentially be those, but I'm still just guessing.
weendoggy
When the vibration starts, put the transmission in neutral and coast. Does it stay? Is it more pronounced at load or coast?
J
joeybuddy96
KY
any chance the rims are dinged up enough to be wobbly or just curbed a few times?
Mostly just curbed. I'm fairly sure I first noticed it before December of last year, but I'm unsure. I hit a semi trailer's wheel in December, so it's possible that could be contributing to it. See photo. I got all four tires checked for balance at two different shops, and both said the wheels were fine. Idk if they spin them at 60mph speeds, though. I've switched around where the most dinged wheel is, but as far as I could tell, the vibrations didn't increase, decrease, or change the direction they're coming from. I paid careful attention today to see if the seat and trim vibrate more than the steering wheel, and it feels like the steering wheel doesn't vibrate as much as the rest of the interior, but I'm going to keep watching for it.
I looked at salvage yard rims, but they were the pre-2004 40th anniversary style. A complete new set of rims that match the style of the body as well as the old ones woild cost like $600.
I've been trying to figure out if the angle of the body could potentially cause vibration. See photos. It looks like the body is higher on the passenger side than the driver side. I already changed out all four shocks, and I'm pretty sure the body was already at an angle prior to changing out the control arm bushings. (I replaced just the bushings on the drivers side, and the entire control arm on the passenger side bc changing out the bushings without a shop press is a long and arduous job). I tightened the control arm bolts with the weight of the car on it, so the curb height on the front should in theory be correct. The gap between the tires and the frame is greater on the passenger side than the drivers side. So idk what's causing that (maybe the control arms need to be set at a different curb height, maybe the coils on one side are more worn out), or if it's something that even needs to be fixed, or how I could go about fixing it.
Lucky57
