All four calipers won't release
J
joeybuddy96
KY
if the abs light comes on and stays on if I am not mistaken it means the fluid is low?
Yeah, it stays on. The codes displayed aren't for low fluid level (they're C1165 and C1222, usually), and I've kept the fluid from falling below the seam on the MC reservoir. At this point, I've done so much air purging of the calipers that I doubt there's any air remaining in the MC or ABS hydraulic unit.
J
joeybuddy96
KY
Got the banjo bolt on the RR caliper tightened to 45 ft lbs and the bleeder to 25. Fiddled around with the metal shims on the RF caliper and checked the ABS sensors on the RR and RF calipers for clearance. Cleared out the DTC errors The ABS codes are still appearing not long after starting the engine. I switched the rear tires, but that didn't prevent the ABS codes from popping back up.
I checked the front tires for bearing wobble, and it's not present. The bearing on the RF isn't completely silent (a light brushing noise), but idk what is normal for that.
I took it for a test drive on the interstate up to 65mph. At slow speeds, I can't hear the scraping noise like I could, so either it just worked itself out, or messing around with the shims had an effect. I didn't see any leaking fluid from any of the brake system parts. The cyclical shuddering vibration is still present and hasn't changed direction. I haven't tried the spare tire thing yet.
The next step with regard to the brake system is to try to figure out why the codes keep reappearing. I've tried a lot of the pinpoint tests from the manual, but not the ones that require taking off the trim and kick guard panel thing to get to the GEM and other modules. I guess the original title of the post is solved-ish. I haven't taken it back to a mechanic to have them try to diagnose the vibration, but I don't think they'll say the brakes are seized up.
cobrajeff96
Germany
I can't remember....did you check the ABS wheel sensors for caked on metal shavings? They are magnetic of course, so it's worth a look if you haven't done so already.
J
joeybuddy96
KY
The shavings brushed off fairly easily, but there weren't many. I replaced the RR sensor about a month ago.
07GtS197
Fort Myers, Fl
That is exactly why I hate the oem brakes. The oem calipers are crap and stick all the time. Also those clips you’re talking about aren’t shims they’re anti rattle clips. I’m sure adjusting them can have an effect though.
You still have the one tire a different size than the others right? Without a new tire you’ll constantly get that code.
cobrajeff96
Germany
The size difference is negligible for SN95 ABS logic. Tire diameter has to be something like half an inch difference before the ABS computer detects too much difference in rotation rate. And thank goodness too because I like having 315 rear tires when currently the widest my car will allow for the front is like 265. As long as tire heights don't stray too far from one another, it's fine and the ABS is happy. This is the case with his tire setup, so I don't think the problem lies there.
On that note, you might check the ABS computer harness for evidence of rat activities. Before this though, swap that wheel sensor from R to L or vice versa like Doggy already said, if you haven't done so already. You might have to have a shop clear the codes unless you can do it yourself (in order to see any code migration).
07GtS197
Fort Myers, Fl
How tires are about 1/2 inch apart. I’m pretty sure that’s his problem. My old white gt had mismatched tires front to rear that were close and I had issues with the abs too.
J
joeybuddy96
KY
C1165 is apparently for the RR ABS sensor, at least according to its entry in the shop manual. Link: https://lemon.dogeware.me/Ford/2004...uick Lookups/DTC Index/Anti-Lock Brakes DTCS/
The code has been appearing either right at engine start-up, or within about 15 mins of driving.
I've switched the sides the 215 and 225 wheels are at (putting the smaller of the four wheels at LR), but the code doesn't change from C1165 to C1175 (for left rear sensor mismatch).
cobrajeff96
Germany
@weendoggy
Front right: 225/55R16 99H
Rear right (the one potentially activating the code): 215/55R16 97W
Front left: 225/55R16 99H
Rear left: 225/55R16 99H
Keep in mind this is more relevant to the ABS codes than the vibration problem. I got all four new tires in an attempt to solve the vibration.
@ttocs That noise wasn't something I'd heard before; that's what made me pop the hood. I could hear it from the driver's seat. It stopped before I could get an audio recording of it. Recently, the ABS light will most often turn on after I've driven for like 15 minutes, but that one time, the green traction symbol on the instrument panel lit up.
He stated all four tire sizes. The only difference I can see here is that one wheel is merely 10mm narrower than the others. They all have same diameter and aspect ratio. The difference therefore is negligible.
J
joeybuddy96
KY
The RR sensor is brand new, if that matters any. I assume the connectors and components of the sensors are swappable, probably the only thing that makes them R or L is the bolt hole. Is that just to verify that the LR sensor is functional? Is there a specific pinpoint test I need to do? I haven't re-done the long list of pinpoint tests since I replaced the old ABS module/hydraulic control unit with the salvage yard one, so I might have to do that whole shlog over again.
The OBDLink scanner I've been using can clear codes, it's just that after a while, the codes come right back. It disallows scanning while the vehicle is in motion, and AndrOBD doesn't have specific vehicle ABS module code reading capability, so I can't just go around the motion restriction using that.
J
joeybuddy96
KY
You need to read, or re-read my post #76.
I swapped the RR and LR. The code did not follow the smaller wheel. The code remains C1165, not C1175 (it would change to that if the wheel was the culprit). Idk what to do next in terms of troubleshooting the ABS codes.
cobrajeff96
Germany
Well, I've heard about junkyard ABS units. Not all, but some weren't stored in the best of conditions when they were taken out of donor cars. Really it's the seals, they need to be constantly exposed to brake fluid or they cinch up over time. Not saying that's the case here, especially since it thinks a wheel speed sensor is to blame. Did these faults coincide with the replacement of the control/hydraulic unit? Or before/after?
Is the unit of the same exact year as your car is? Model as well? I'm not 100% certain this way or that, but perhaps the year and model do factor in many cases. Maybe not all, but certainly some.
weendoggy
Here's something to keep you busy. Follow the symptom. It's close enough for your car. I highlighted the area you're questioning.
  • abs_testing.pdf
J
joeybuddy96
KY
@cobrajeff96
Over on the stangnet forums, I wrote on June 28 that no ABS codes were showing up at all, despite both the ABS light and TRAC OFF lights being lit. I took it to a retailer for them to scan it, and only the engine errors from the o2 sensors being bad were showing up (this was before I replaced them). If I recall correctly, clearing the codes wouldn't turn off the ABS lights even during just the ignition. I could be wrong about that, though, but it definitely would display as soon as the engine was started. The tires would skid during testing, meaning it wasn't just a false positive from the instrument panel or smth. So what it had was an uninterrupted failure rate of 100%, versus what it's got now, which is the ABS errors popping up at seemingly random intervals.
By July 14, I got an OBDLink MX+ scanner, but it was the same scenario: no ABS codes, but with an ABS light. That's when I did a bunch (but not all) of the pinpoint tests from the shop manual.
By August 30, I got the salvage yard ABS module/hydraulic controller. The hydraulic controller still had all of the brake fluid in it, and I did the swap within about a week. I still have the old one, but if the valve seal thing getting deteriorated from going dry has affected it, the hydraulic controller is ruined and useless by now. That's when I actually finally got the system to give me some kind of code, as opposed to it giving me no info on what was wrong at all. The car I pulled it from was a 2004 4.6L. Afaik, the Cobra model is different (and maybe the Mach/GT model), since I've seen ebay listings with "COBRA" printed on them, whereas the 3.8L and 4.6L just have "V6 TRACTION". but the 4.6L is not different. I'm going to claim there's probably no difference between the two base models. The only difference that I could tell was the barcodes of the two modules, but I assume that's the serial number, not the model number.
@weendoggy Yeah, I haven't re-done the pinpoint tests after I installed the salvage yard ABS unit, so I plan on doing that this weekend if I can (still have to work on the fuel pump stuff and transmission pan gasket stuff).
During the last hour of driving today, the ABS light has been off, so I ran the scanner and the codes were showing up there, so pinpoint test J might give me some info, too. The bulb isn't burnt out, it just didn't light up while the errors have been stored this one time. Hopefully that isn't yet another new problem.
again I am fairly sure that if the abs lights comes on and stays on that the level is low, it is when it is flashing when it has codes to read.
07GtS197
Fort Myers, Fl
The parking brake light is the one that comes on when brake fluid is low.
Another thing to keep in mind is that this generation of Mustang used an abs controller that is a known failure point. If it’s the same codes for both modules it’s probably not but it’s something to keep in mind.
weendoggy
With the water issue (leaks) the OP says is in the car, I supplied information for him to check. Connections, etc. are places to check as well as damaged wiring. Too much time spent replacing this and that without going to basics, the most often overlooked part of diagnosing the problem.
Lucky57
