another pi head swap question
i8ur-riceburner
this is my first post to the boards i have a 98 auto gt, my mods are 4.10's, diablo tune, mac long tubes, mac prochamber, flowmaster 40's, msd ignition coils/wires, and ngk spark plugs.. i have bought windsor heads, cams, and intake and i plan to get a stage 3 port job on them with vt stage 2 cams now a question witht he parts i need i no i need 13 bolt valve covers but do i need anything else besides the following.. and a question for the head changing kit is, is it the same for romeo and windsor?
intake gskt
alt brkt
coolant tube
thermstat housing o-ring
water pump o-ring
upper plenum o-ring
coolant tube nipple
and the ford head changing kit
DropTopPony
South Jersey
welcome!
head changing kit is good for both heads...you will also need different bolts for your timing cover into the heads. They are 10mm for Windsor and 8mm for Romeo heads.
Dalamar
SLC, UT
Looks like your all set! should be sweet with those cams and porting :thumb:
Testguy
