another pi
black98gt
just wanting some advice about the swap. i was thinkin about vt stage 2 heads with vt stage 2 cams with p51 intake what kinda numbers would that give me and does that sound loike a good investment. also does anyone know anything about the anderson psm tuner? thanks alot
svtboy
stock pi intake, cams, and a s-trim... Less money then you will spend on all that and more horsepower.
Pennywise2
Personaly I would go straight for the VT stage one heads and cams
because I like the fact that the VT stage one cams produce power earlier
in the powerband as the VT stage two cams produce alot of their power
higher in the powerband.
Go with the VT cylinder heads and cams if you can afford it.
All the VT products are worth it! O0
Give Scott or Jim a call and they will help you every step of the way.
VT engines' customer service is second to none.
Bullittfan
