Another problem
RIFTER11
Nashvegas
after installing my 75mm t-body, my idle is kind of messed up. :santa_angry: before - idle was normally around 750-800rpm.
after - idle is now at 1000rpm and it stays at 1500rpm when you push the clutch in when coming to a stop. after you completely stop, the idle goes back down to 1000rpm. anyone have a similar experience or adivce on what i need to do to fix it :dunno: :santa_huh:
Lightning Struck
I remember seeing something on this a while back, :santa_undecided: let me see if I can find that thread.
DropTopPony
South Jersey
after installing a TB/Plenum/CAI etc the computer will need to relearn and adjust itself...did you unhook the battery for atleast 5 minutes before you finished? If not do it....it can take up to a week for the idle to get to normal but it will eventually.
97vertstang
unhook the battery for 30 min. than hook it back up. the computer needs to relearn.
96gt226410
That happened to me, too. After I reset the computer it was still doing it. After that, I replaced my throttle body gasket and it was fine. There was a vacuum leak causing idle to stick.
RobertC
