Any last ditch efforts?
Daryl
Somis, CA
Now I’m wondering if there are “other” things I can do to help me pass smog (here in CA).
Since I’m running way too rich, and my tuner having once already trimmed my tune down down which had negligible effect, maybe different throttle body (currently BBK 75mm)? Or fuel injectors (currently 24lb)? I’ll go so far as the fuel pump if I have to.
Any thoughts, suggestions or comments?
If this doesn’t turn into something, I have set up a USPS account online and could register the car in a CA county that doesn’t require smog tests, but I’m not sure how to re-register the car to the new county and do it to not raise suspicion with the CA DMV &/or CARB
shovel
If we're talking legit last ditch...
I haven't lived in California since the 90's - it's weird how many people on youtube & motorsport tv live in California and manage to have highly modified cars which still get California plates, they make it seem routine.
What do you mean still running way too rich? On a modern aftermarket ECU like Holley or Stinger that kind of stuff is a breeze to deal with but I'm assuming you're using an oldschool quarterhorse or whatever to continue using the factory ECU
Daryl
Daryl
Somis, CA
OE ECU
shovel
I wish I had some practical advice for you, or enough discretionary $ to adopt your Cobra & give it a good home. You've spent a lot trying to solve this emissions puzzle and it's discouraging to throw more money at it and not even be 100% sure that will be the end of it.
If it's running rich at all times, perhaps an adjustable fuel pressure regulator to dial back fuel delivery at least while getting smog inspected? I unfortunately can't find the part number at the moment but there's a very stock-appearing adjustable regulator that fits our 94/95 two bolt flange, with the screw hidden inside the vac reference hose. I used one on my 94 when I still used the stock fuel rail & ECU.
Terrorist 5.0
Tee into your exhaust in a place nobody will see, and route it to a charcoal canister in the cabin perhaps? Lessen whatever the smog test sees ;)
did you have these problems with the 19 lb injectors? I would consider removing them and having them tested, calibrated and cleaned.
Daryl
Daryl
Somis, CA
Definitely worth looking into it, thanks!
Daryl
Daryl
Somis, CA
I’ve only ever had the 24lb injectors, so I don’t have an answer for you there. Are 19lb injectors stock?
19 is stock on gt, 24 stock on the cobra. If you are not using the right maf or tuned to compensate, that could be your problem right there.
Daryl
Daryl
Somis, CA
I recently replaced the MAF sensor with a Delphi unit listed as a OE replacement. The car has since been tuned to include the new MAF
well being it is a cobra it should be ok, but I would still test the injectors. Cheap is to pull them and find a place to test, easy/expensive is swap them out and see if it goes away.
weendoggy
Being pre OBDII, it requires the "sniff" test at idle and mid-range. It also has to pass visual. If any replacement part is used, it MUST have CARB EO. If this is NOT stock, you're going to go round and round, like you have, trying to get something to pass that isn't stock, no chip, injectors(fuel), headers, non-CARB exhaust, vapor, etc.
joemomma
Is the Holley aftermarket ECU CARB-approved? That seems like the best move going forward if you're wanting to try and keep the car.
RAU03MACH
NEW MEXICO
my question is
did you think about all of this before stroking the engine
every thing changes when an engine has been modified
these people in California are doing it the right way with newer cars not older cars
its all easy on a newer cars the older cars there making it harder to keep registered
and off the street
cobrajeff96
Germany
I want to say that 94-95 also had O2 pumps just like my 96 had. If the exh manifolds are original (and a lot of times even aftermarket too), you'll see a threaded nipple on the front of the first primary tube (forget which side of the car but I want to say driver) where a hose threads onto it to inject fresh air from the O2 pump which helps to dilute smog and help these cars pass emissions from the factory. It's worth looking at.
shovel
On my 94 it had a few miles of plumbing and two vacuum actuated valves that would send air into the rear of the cylinder heads, where it would dump into the exhaust stream just behind the exhaust valves during warm-up to enrich the upstream cats, then after warm-up the valves would divert the air instead to a tube which feeds the downstream catalytic converters directly. The vacuum operated valves were directed by a pair of solenoids above the passenger tire inside the fender, only accessible by removing the tire and liner. There is a third solenoid mounted there as well I believe to operate EGR. I do not know the specifics of the strategy in the ECU to command these things.
weendoggy
No, it or any other one is not CARB approved. Reason, you can mess with (adjust) settings.
Lucky57
