Anyone putting down 300rwhp or more N/A......
98mstanggt
98mstanggt
Louisiana
In the Video I was hoping to hear u rev that baby or even do a drive by lol......... But yeah I'm get my tuned to 6500rpm that why them cams really can show off......ima try to go to the track to see what I run in 1/4 mile with the mods I got now...... I wanna see your numbers and track times
simplyme0484
LOL.... I'm gona make a better video soon, and you'll seen the beast roar and go :hammer:. That was just a quick vid.
98mstanggt
98mstanggt
Louisiana
Aight thats cool so what's your next move or u gone enjoy your car how it is for a lil while...... My mechanic keep trying to convience me to get a procharger lol
McCloud
Johnson City, TN
I have VT Stg II cams, more agressive than the comp 274s and I dont need to rev my car to 6600. Given I have stock heads and PI intake, I stop making power around 5900 and then level off. Unless you have a built bottom end, revving it to 7200 is just gonna end up in heartbreak for you.
Oh and 98mstanggt, you are wasting your time ordering a 2600 rpm stall. The stock one is rated at 2750! Go with a 3500 at the minimum!
simplyme0484
Well I have st.3 ported heads and the typhoon IM, my car keeps producing HP until the 6600 rpm. I'm not reving it until 7200 (we just test it), even when I go down 2 and 1 gear, I throw and rev till 6500 rpm. Cams alone won't produce that much power if not backed up with heads, headers, IM, ect..
98mstanggt
98mstanggt
Louisiana
Man to tell you the truth idk what stall ima use...... Comp Cam state u need a 2000+ stall with the 274h Cams, some say I'll stock stall is 1800 some say 2600 so I really dont know which one to get......
Outlaw97GT
If I remember right the stock stall is 2600-2800ish... I have a 3000 stall (from previous owner) and its not enough.
Man I can wait to see what kind of numbers you through down..... Car sounds awesome :thumb:
98mstanggt
98mstanggt
Louisiana
Ima have to do some research about our stall cause I need some proof ha ha........
Man I just installed my 3.73s the other day n I gotta a weird noise coming from the rearend any idea what this might be my mechanic said after a couple days it should go away but idk
No less than 3500 with stock cams,and no less than 4000 with a set of cams-maybe more. I run a 4000rpm converter in my car,and it's barely enough with a 4.30 gear. I've got ported heads,and Comp 270AH cams,and peak power is at 6000 rpms.
JL
98mstanggt said:
3500-4000 stall Just seem like too much for a daily driver
Flawed dinosaur (60's non-lockup auto trans) thinking. With a lockup converter and the EEC tuned properly for lockup schedule,the only time it's different from stock is in 1st gear. I drive mine all the time,and it gets just over 20mpg on the highway with the A/C on.
JL
98mstanggt
98mstanggt
Louisiana
JL
Well i got plenty of time to decide which stall to get so hopefully i get the right one for my car.............. Ima look into some more because i dont wanna put the head n cams on without the stall so :dunno:
navarro98gt
What kind of Fuel injectors & MAF setup are you guys running? I just got my car back from getting dyno-tuned and my tuner said that I maxed out the stock 19lb injectors at 284rwhp @ 5200rpm . Mods below………
1998 Mustang GT Auto
2001 P&P PI heads, valve job
CMS Stage 2 n/a cams
C&L plenum
75mm t-body
Hooker longtubes
o/r X pipe
Mac Catback
C&L plenum
75mm t-body
Hooker longtubes
o/r X pipe
Mac Catback
I'm running 24lb/hr injectors and an 80mm Lightning MAF. The OE MAF is sufficient for a N/A application-I use the Lightning piece because I got it cheap.
JL
navarro98gt
[/quote]
JL
[/quote]
So I probably wouldn’t benefit with a lightning MAF? And 24lb/hr injectors will be good enough?
98mstanggt
98mstanggt
Louisiana
JL
[/quote]Well I'm still running my stock injectors n maf sensor right now but when I put my heads n cams I'm running 24lb injectors n a 190lph fuel Pump with that u shouldn't have any fuel problems....... But as far as the lightning Maf I heard u don't really gain anything switching from stock to a larger Maf maybe a couple horses correct me if I'm wrong
[/quote]
98mstanggt
98mstanggt
Louisiana
navarro98gt said:
So where did you guys buy your injectors?
I havent purchased mine yet so i really couldnt tell u but just about any Mustang site sell them though :thumb:
rvseverson
