9838stang
That could be... Come to think of it, mine was broke so that is possible why I changed it... But I think the latch system is a bit smaller... Lol I'll have to look. It has been 3 years lol
I will have to post a couple of pictures when i get home this afternoon, I forgot i hadn't done that lol. The only issue, I cannot use my cigarrette/a/c port when the cup holder is out. It bolts right in and i had to just cut two small notches into the console just do the cup holder would sit flush and lay flat. The 94-97 console lids are magnetic, and the 98 -up are latch types. So i had to make a magnetic catch... I took it from the old console i robbed at U-pull
How did you get it in with the cig lighter still there? Mine won't go down all the way because of it...
I have also been trying to figure out how to make the magnetic latch work. What exactly did you do????
I actually had to pull the cig lighter out of place, I put the center console compartment into place. Once the I had it in place. I was able to push the lighter a tab bit hard back into place
I didnt really have to modify anything on the cig lighter.
But i took the magnet from the center console, layered it up so that it would fill the place of the old latch. I ended up using the cloth electrical tape and gorilla glued it into place.
I also had to slightly trim the the 98 console so that the magnet would sit up high enough i believe
