Axle Shaft Kits?
Denunzio36
Does anyone know where I can find a good, fair priced axle shaft kit?
I hit a curb with my stang and snapped the back left wheel right off, clean break.
I am going to purcahse a set of shafts and do both while I'm into it with 31 splines...any sugestions?
Thes best deal I found so far was - Alloy USA for 209.95 (shafts, seals and bearings).... any good?
How does this compare to Moser? Please let me know..I have to buy them soon
wytstang
Superior axles are really well built summit racing sells them. They are strong this is one item that you should go cheap on if you can help it.
BLOWNCO
moser are only 250$ thats 50 more an axle you would have to spend and moser axle's deff a good investment
Denunzio36
So, this is ok to go cheap on? I'm guessing this part is made very similarly among the different manufacturers?
So, will the Alloy USA be ok?
Denunzio36
Do I have to make any other mods to accomodate the 31 spline? They just replace 28 with no problem? Let me know. Thanks
wytstang
You have to swap out the differential/chunk to a 31 spline as well.....
FlyBy347
