scca_stang
anyone have a suggestion for a battery for a car that doesnt get driven all the time?
I have an Optima and it wont hold a charge
Maybe your battery is good but there is something draining it. Try charging it up, then disconnecting the battery cables. If it holds a charge then, it isn't the battery. My Optima didn't hold a charge very long either, but I found the dome light was staying on. I disconnected it and that stopped all the problems.
I know a few people that are still lucky like you but I know more people in the 12v industry that switched to other brands that did not lower quality over the years. Its not uncommon as making good batteries is both expensive and easy to cheap out on and say it doesn't matter, but it does. Same thing happened with Kinetik batteries. Earlier this year when I was looking into AGM batteries I was told by my buddies still in the industry that odyssey was who I should check out.
Optima isn't the brand it use to be. IF it isn't being driven often an agm might be better then a standard battery.
Why not fix the dome light?
