BAttery Cables
Discussion in '94-95 5.0 - Specific' started by bmcgc, Feb 11, 2016.
  1. bmcgc
    bmcgc Member
    152
    Mar 21, 2015
    I had to rescue the misses again yesterday due to the positive battery cable.
    This time it was in the wind and snow, at least it wasn't dark.
    Im working on removing the cables for replacement. With what I have no idea yet. I can build a 65 fastback from scratch out of a catalog, but I cant buy a 94GT battery cable.
    Anyway, how to I pull this connector apart without breaking it?
    [​IMG]
  2. Witzy0070
    Witzy0070 Active Member
    836
    Dec 10, 2009
    Montana
    You can totally cut the wires and reattach them with butt connectors.
  3. bmcgc
    bmcgc Member
    152
    Mar 21, 2015
    That's not going to happen. This car is in mint condition with 50,000 miles. Im keeping it as original as I can.
  4. lutter94
    lutter94 Well-Known Member
    3,023
    139
    Apr 11, 2008
    South Dakota/Iowa
    sounds like you need to go to a junkyard then. If you can't replace a connector with a different style. Do you expect to find an OEM NOS battery cable on eBay?
  5. bmcgc
    bmcgc Member
    152
    Mar 21, 2015
    Im sure there are NOS cables out there. Its just a matter of finding them.
    I find NOS stuff for my 64 F100 all the time.
    I will probably end up finding a replacement that is close enough to the oem part to pass. Ive got a few leads.
  6. evilcw311
    evilcw311 Most Evil Member! SN95 Supporter
    7,459
    2,080
    May 9, 2010
    Louisville, KY
    Ok so finding replacement parts for a vintage vehicle and a 90's mustang is so apples to oranges.
    Doesn't matter if it has 5,000 or 50,000 or 500,000 on it. It's a 94 mustang, not a 65 Shelby. Your not hurting any special value by eliminating that fuseable link.
    Junkyard is only place your gonna get one and then you could be in same boat again.
  7. joekd
    joekd Well-Known Member
    3,968
    124
    Jan 14, 2009
    Ct
    Exactly my thought, unless your car is going for Concours type points no value will be lost by a non-oem battery cable on a 94 Mustang GT
    I had these aftermarket terminals and aftermarket battery in my 96 GT, believe it or not I was still able to sell the car
    [​IMG]
  8. lwarrior1016
    lwarrior1016 Moderator Staff SN95 Supporter
    5,856
    973
    Sep 22, 2014
    South Mississippi
    ^ I didnt know energizer made car batteries......thats pretty cool.
  9. joekd
    3,968
    124
    Jan 14, 2009
    Ct
    It came with the car when I bought it, honestly the label annoyed me, I ended up spraying to top of the battery with plastidip so it was all plain black but I could still peel it off if needed
  10. ttocs
    ttocs Post Whore
    26,125
    2,925
    if the fusable link is bugging you there are battery terminals that allow for one of the wires coming out of it to be fused right on top of the terminal.
  11. ranger56528
    ranger56528 Active Member
    907
    Aug 20, 2015
    West central Mn
    Round coller with 2 tabs,you squeeze the 2 tabs witch expands the coller and pull a part,it takes some time to get the hang of ot and it's the same putting it back together,you know it's back together when you can't see the orange o ring,it does take some trial and error but when you get the hang of it it's not to bad,I did mine a few times a couple weeks ago trying to fix a wiring issue.
    check eBay for the cable,I've found a few listed there,pos and neg and there not cheep.
  12. Cpotts13
    Cpotts13 Well-Known Member
    1,594
    36
    Mar 11, 2012
    Biloxi, MS
    Mine came with one too... weird...
    Sent from my SAMSUNG-SM-N920A using Tapatalk
