Battery light on
Daryl
SoCal
Great. Since I got the car back with new clutch, transmission and drive shaft, the red battery light has been on!
I just replaced the battery and the car starts per usual even with the battery light on.
I’m going to check and see if/where the plug in is so when I stop at VatoZone on the way home from work, maybe that’ll diagnose it. Or tell me how to clear it.
Of course I’ll check the battery with the volt meter too
is the battery dying? or just the light on? If you are having to jump it, then its the alt. If the light just stays on but it keeps starting it might be charging a little low, or there could be a problem with the circuit
RAU03MACH
NEW MEXICO
he just put a new battery in it , but you never know that battery could crap out to
cobrajeff96
Germany
Battery light can tell you multiple things. But I think in your case it's telling it's undervolted (meaning 95opal is most likely correct in what they said).
95opal
12.5v on the volt meter
Is that batt voltage or is that voltage with the car running?
Your batt light is on because you arent getting enough voltage on the charge side.
Could be bad alt, bad ground, faulty wiring. Either way if that light is on your not getting a charge from the alt.
if your only seeing 12.5 with it running then the alt is probably on the way out. Of course with electrical and recent work it might not be a stupid idea to check your grounds to be sure a mechanic didn't leave one off. You always want to start simple with electrical so it would not be a dumb idea to inspect all your fuses as well.
Daryl
Daryl
SoCal
Battery voltage; engine not on or running/idling
Daryl
Daryl
SoCal
14.6v on the alternator check with the voltmeter.
Time to chase the negative wire for ground and check for corrosion !
Daryl
Daryl
SoCal
I think I found the likely culprit:
The negative wire coming off the battery is pretty badly frayed at the right-angle just before where it secures and grounds at the motor.
cobrajeff96
Germany
That might not be it. Only way to be sure is to ohm it out from one end of it to the other, or just from that connector to the (-) battery.
Daryl
Daryl
SoCal
How do you do that??
get a multimeter and set it to restistance/ohms. Put one lead on the lug where it attaches to the motor, put the other on the batter and that will tell you the resistance in the wire. It should be very very low/close to 0.
cobrajeff96
Germany
I think it's at most you want one-tenth of an ohm, anything more is a little too much. Just remember you want to measure the path in question and that should always tell you your start/end points to touch the multimeter leads to.
Daryl
Daryl
SoCal
Thanks, gents! I appreciate all the advice and guidance. I’ll check it out today and report back…
Daryl
Daryl
SoCal
Does the engine have to be on ?
TN95gt
