bbk intake will it work?
txlen
yep...i went ahead and stripped the upper to bare so it would look like the lower...i don't like 2 toned intakes...and i turned the intake around with the throttle body to the drivers side...
txlen
Clark...what kinda numbers did ya put down??...Len
69clark
Well the combo should make about 500hp or so at the crank. I have had it on the dyno since I did the motor, but last year with the stock motor (everything from block to intake) and sc setup it put down 376 hp and 396torque which is about 430 at the crank. So now with a new internals, afr, fti cam, and intake 500hp at the crank should be in the ballpark.
I like the way the gray finish was but I went ahead and made it low gloss black, help match the engine compartment better.
emjohn43
