BBK SSI
ANG
can someone tell me why the BBK SSI Intake won't fit on the 5.0 SN95s?
I think they look badass and the output (or input I guess I should say) is giving some good numbers for all lthe Foxes.
Discuss.... thank you :dancing6:
94darkhorse
Idawahio
You can put it on as far as I know. The only thing you really have to do is convert your tb to the fox style, instead of ours.
95 Sleeper
Yep it does, you can either swap to the foxbody style TB or just buy the adapter elbow and run your TB
MeanGrn Gt
you just need the elbow i believe. It is just like all the other 5.0 intakes because they are a direct fit for a fox instead of a 94-95.
A
ANG
All I can say is wow
that looks sooo awesome.... I guess I'm gonna have to do some searchin' on the numbers he's putting down....
momma likes!
69clark
They fit. Only issue is that you need to run a cowl hood. It is said that they won't fit under the stock hood. That is why it is listed this way. Also the fuel rails are setup to run the fox style fpr, so you will need that and also either fox tb conversion or 94/95 elbow.
I have not dynoed since putting this engine together, but it should be atleast 500hp at the crank.
jpajkos
Clark clean motor man. Defiantly one of the best i've seen.
SvtBlack95
hey man what kind of blower is that on your stang i have never seen that kinda of design before??
69clark
paxton VR-4. Its an sn series ball-drive blower. The vr-4 was the race supercharger in those days. The SN series was what paxton had before the Novi line hit the market.
wbarter
Staff online
