Bleeding brakes & Wheel Stud Question
Matt94GT
Hey all what is the proper method for bleeding our brakes? Rear passenger, rear driver, passenger front, driver front? Have to bench bleed a MC then re-install and bleed my brakes.
Also whats the procedure for replacing a wheel stud that I broke, whats the best way to remove and reinstall one? also what are the specs of ours so I can get a new one at my local autoparts store.
thanks
blackfang
I always use an air hammer to tap out the broken stud, then use it to push it through. If you are going to hammer on the axle, atleast be consistent. I forget the studs specs on mine, yet I have replaced them.
STNG_96
I dont know that a c-clamp would put enough force on it. You could always just use a normal hammer, just be CAREFUL! As far as bleeding the brakes, I want to say all you have to do is pump them several times. Im pretty sure out cars have a bleedoff valve on them, to get rid of any air. If your not satisfied with that, just take the cap off the brake fluid resivoir, and pump them, it will pump the air out.
Matt94GT
Matt94GT
Ill try that but I want to crack the bleed screws at the calipers, im assuimg the order is Rear passenger, rear driver, passenger front, driver front but some cars are diffrent can anyone confirm?
Cobra456hp
lube it. grab an old lug. put it on over the stud. grab a BFH. knock the shit out of it. till its loose. put in the new STEEL stud and thread a STEEL open lug nut down. as you are tightening the lug it will pull the stud through the axle.
wayne94mustang
yeah Matt...you always start bleeding at the farthest wheel away from the MC and work your way to the closest.
iv replaced many studs...just use a old lug nut and a hammer to get the old ones off and just beat them back on
Cobra456hp
No prob. Just make sure that you use a good grade stud. Not those cheap POS aluminum from autozone/advance.
Cobra456hp
you can get one any autoparts store. justa make sure its of good quality. The alluminum ones will strip and crossthread very easy.
jdude138
