Anyone have experience with these heads? http://www.theengineshop.com/products/bmp-sbf-10-aluminum-heads.html
What short block would either of you use these on? If you aren't planning for big cubes or spinning past 7k rpms you don't need these heads.
Every now and then heads like these pop up and everyone gets excited. Flow numbers are not the end all and be all of cylinder heads. The quality of the parts being used on those heads will be questionable. Stick with a quality cylinder head from AFR or Trick flow you'll be happier in the end.
