Bog at low rpm - 98 Cobra
Tony281
Houston TX USA
Hello, this is my first post. I have a 1998 Mustang cobra and it’s bogging down only on low RPMs. I bought it brand new in 97 and it might’ve been tuned. I don’t drive it much anymore, but wanting to figure out what the issue is. if it was tuned, then I have both of the mass air meters that I have had on the car so and I have switched them out and it doesn’t make a difference. I thought for certain it was the mass air meter.
I took it to a specialist and he hooked it up to the machine and what it’s saying is that it’s rich, but he was not able to fix the issue because he said it was tuned. I talked to someone who does tuning and he said the 98 Cobra has an issue with the PCM and it’s very likely thats what the problem is or that it could be the harness.Noting that I also had some vacuum leaks, and those were fixed. I did have a set of pulleys on it and if it was tuned with the pulleys and they were taken off I’m wondering if that could be messing with the computer and causing the bog.
Wondering if anyone else has had issues like this and come to find out it was the PCM.
Thank you
I don’t know that much about cars
RAU03MACH
NEW MEXICO
so you bought the car brand new in 97 and you have no idea if you installed a tune
just what im reading
first pop the kick panel on passenger side floorboard under dash by door
look at the computer is anything hanging out besides the wire harness connector
it would be the opposite end of computer, if only the connector i would say not
that is a start
T
Tony281
Houston TX USA
that is a start
Hi, i found out what was causing the misfire. The SPARK PLUG WIRES! I replaces them and it now runs perfectly. I guess they were arcing. I had really no confidence that replacing the spark plug wires was gonna make any difference because I had already replaced the coil and did the spark plugs too, and that made no difference at all, but the spark plug wires made a huge difference and I have no hesitation or misfires or anything at all RPM levels.
Pretty amazing that spark plug wires can make that much of a difference. I am glad that I figured it out on my own. I was pretty sure that it was the PCM and the mechanic I took it to also said it’s likely it’s the PCM but nobody bothered thinking it was something much more simple than that.
Thanks for the response.
96blak54
Staff member
Lawrenceburg Kentucky
WOW!
The plug wires must have been spent! Ive learned alot over the years with these modulars and sparkplug wires, but never would have guessed wires to be your problem. Glad you got it figured out tho!
Hey be sure to create a build thread in the build ups project thread. Snap some pictures and keep it updated. Its an awesome way to journal your cars progress and we all love seeing what you do!
Lucky57
