Rear interior panel swapped
Mounting plates removed
Weight reduction: -7 lbs
My car use to have a half azz 6 point cage that I cut out when I first got it. The rear bar mounting plates were connected to the wheel wells which I’m not a fan of and were only pinched welded in. The rear quarter panels had also been sliced in half and cut open to accommodate the bars. When I initially cut the cage out, I left all the mounting plates in place and patched the panels.
I removed the interior with my little man; actually he did the full removal to swap the rear interior panels and remove the mounting plates.
Little man in action
Removed the insulation behind the panels and from under the rear seat. Those three pieces were 2.5 lbs
The mounting plates were then grinded out. Just the rear two were 4.5 lbs. I'm going to remove the other 4 plates eventually as they're mickey mouse too.
I then added some heat tape to the floor tunnel area and under the seat as I was getting a bit of heat coming up. We’ll see how that works.
With everything removed, I then coated all the panels/floor with the truck bed liner spray that I’ve been using. This stuff works great and really does reduce noise and vibrations!
New panels installed and everything back together
Current - 3,389.5 lb
