Ill put a list together for you in just a few minutes.
I will link all this from ebay just because its easier.
Main studs
http://www.ebay.com/itm/ARP-Ford-Mo...ash=item4ad4e1640e:g:Gf4AAOxyuR5TaHQq&vxp=mtr
Head studs
http://www.ebay.com/itm/ARP-HEAD-ST...ash=item2cac3e552d:g:jWUAAOSwYmZXMOXO&vxp=mtr
Clevite main bearings
http://www.ebay.com/itm/Clevite-77-...ash=item2eeaa15192:g:NdcAAOSwpRRWmnJD&vxp=mtr
Clevite rod bearings
http://www.ebay.com/itm/Ford-4-6-4-...ash=item2c6756ef43:g:0soAAOxydB1Sh-3m&vxp=mtr
A master seal and gasket kit will be needed. No need for header bolts, the stock stuff will work fine. As far as bottom end, this should do it.
You're the man (name?)!! My header bolts looks super rusted, so not sure if those would be a good idea or not?
Sean
If it already has ARP stuff in there you can re-use it. If not you have to either buy new stock stuff or if you want to do it right... yeah you need to spend that.
I'd still be getting a whole pullout if I were you...
Also for what you are doing, meth an the intercooler is total overkill and I personally don't like meth. Just one more thing to worry about and one more thing to go wrong.
The CX racing kit is good but the intercooler is a cork. Either call them and get the intercooler upgraded to the 4" core unit or just get the tubing minus the intercooler and get a Treadstone intercooler. I got CX to send me a 4" intercooler and I'm installing the same kit.
Blow thru... you'll want a slot MAF, that'll be $200 plus whatever it costs to have an exhaust shop weld the flange into the intake tubing.
Really does depend on what your budget is. If you have $2500... $600 for the 4" core CX unit, $700 for that motor, $200 for a MAF, $600 for a good tune. That's almost your entire $2500 right there. You don't have the $$$ for machine work and forged parts TBTH...
William is the name, lol. As long as the nut come off and dont break the studs, you should be ok. The head studs, well Scotty nailed it. See if you might have them already and if you do, reuse them. If not, itll be something to look at. I wont put my engines together without them.
Is something like this master gasket set complete overkill? http://www.summitracing.com/parts/slp-260-1689/overview/make/ford
Just trying to only do what I need but at the same time won't skimp on anything important.
Sean
If you are doing a drop in engine, then I would do just that. Drop in a completely stock engine and enjoy the car, but drive it easy. Meanwhile, rebuild/build your current engine so that when its ready you will be able to drop it in there and have a bunch of fun. Thats just the way I would do things. That gasket kit looks to be pretty well complete. You can find better deals on them if you shop around. I use ebay for a lot of things.
Is there cutting with an intercooler... Lolololol. Mr Crash bar say hello to Mr Sawzall
