Braking
04rustang
Hi The problem, right front caliper is hanging/sticking after 2-3 miles. REPLACED pads both front calipers, with NEW hardware, hoses. BLED with motor running and with motor off, ran 1-2 pints threw while tapping on brake caliper[corvette trick]Bled rear brakes, ran 1 pint threw to get new fluid in. I thought about replacing the master cylinder BUT the left one dose not hang up and stays cool.THE car is a '04 v6 ragtop, auto,Picked it up 10-06-14 in clearwater FL. Drove it home to WIS. Stored it Was going over it, Put lower ball joints in,put a new alternater in on the way home. New battery this April. I even pulled the ABS 50amp fuse in under the hood for a drive still gets hot but don't seam to pull to the right. Had an alinement done when the ball joints in. What am I missing?? Thank You for your time.
What about the guide pins? The caliper floats on these and if they are bent or are not allowing the calipers to side, it will feel like it's binding up.
TreeScholar
