joemomma
- Joined
- Dec 9, 2020
- Messages
- 1,242
- Reaction score
- 754
Looking good man! Also, that may be the cleanest garage I've ever seen.
What trans/shifter is that? I like the looks of that handle. My Hurst basically just barely clears the dash - I have to kind of grab it from the side to get a good grip on it.
I had the same problem with my hurst, if I were to slam in 1/3/5 I would hit my knuckles on the dash. I have seen people make a cut or two on the back of the handle and then bend it back and weld it back into place or replace it with a pro 5.0 handle.What trans/shifter is that? I like the looks of that handle. My Hurst basically just barely clears the dash - I have to kind of grab it from the side to get a good grip on it.
it sounds like the hanging idle is in the tune. If your ecu works like my holley does you program what %open(I think mine is at 35%) you want the IAC to stay at and then there is a decay rate that once the rpms get down below a certain point, then it starts closing to the 4-5% that it should be open when at idle.
Now if you have not already done a smoke check to look for vac leaks this is the time to go get a cigar.
